what valve springs and roller rockers to use
Old Dec 17, 2011 | 10:14 PM
kamasutra8769's Avatar
hey guys how it going. i have a 94 z28 camaro. Dont have alot done at the moment. 10.5 mm plug wires, drilled and slotted rotors with ceramic pads, Front strut bar, Cold Air Intake, Freshly rebuilt tranny with shift kit, new pacesetter long tube headers and y pipe with magna flow cat back(not installed yet). Im looking to put a cam in it. I have asked around and i have been pointed to the lt4 hot cam. Im not looking for a big cam, as this car will still be a normal driver. but what roller rockers and valve springs should i use with it. also im not looking to spend a **** ton of money. any pointers would be great. thanks guys.
Old Dec 18, 2011 | 12:07 AM
englundjd's Avatar
Re: what valve springs and roller rockers to use
well if your not looking to spend much i think the LT4 springs will handle the LT4 hotcam, ...i think maybe someone can answer that
as far as rockers go you got a lot of options;
crane
compcams
scorpion
id go with the 1.6 ratio
Old Dec 18, 2011 | 12:32 AM
97WS6SCharged's Avatar
If you're looking at the hot cam just buy the whole kit and you get springs and 1.6 crane rockers.
Old Dec 18, 2011 | 11:37 AM
TeeTopZ's Avatar
^ what he said. The kit comes with everything you need. No guessing. I think Jegs has it for the best price.
Old Dec 18, 2011 | 01:45 PM
Bykerboy869's Avatar
heres a link to the kit on jegs. and what TeeTopZ said it is the cheapest at Jegs
GM Performance 12480002 GM Performance Small-Block V8 Camshaft Kit
Old Dec 18, 2011 | 02:32 PM
ok thanks guys, im going to purchase this kit, what are roller tappets? on that site it says those are not included! also, what gear ratio do i have, i changed the fluid today in my differential and the big gear says 15:41. what does that come out to? also, what are some other pretty easy/cheaper ways to add horse power. Im not looking to do a wet kit. this car is too nice to put it thru that. any other idea would be great, suspension ect. remember will still be a daily driver!. thanks
Old Dec 18, 2011 | 02:37 PM
"Roller tappets" are the roller lifters. They are not included. Stockers work fine.
41/15 = 2.73
Your RPO build tag should indicate GU2. That is the ratio supplied with the base V8 automatics. To get the 3.23 rear axle ratio, it had to be ordered with the GU5 "performance rear axle".
Time to add a "signature".
Old Dec 18, 2011 | 02:51 PM
i dont know how to add a signature !
Old Dec 18, 2011 | 02:59 PM
Go to the red task bar at the top of every page. Left click on "UserCP". On the drop-down, left click on "Edit Signature". Enter your signature info on the "Edit Signature" screen that appears. At the bottom click "Preview" to verify it appears as you want it, then click "save".
I generally recommend you show - year, model, engine, trans and any major modifications. Links to photos can be included (but not the photos themselves). Unfortunately, the code for the links eats up a lot of the available character limit.
Old Dec 18, 2011 | 04:16 PM
ok is this better?
Old Dec 19, 2011 | 12:44 AM
Suspension is never a bad choice along with subframe connectors. One really nice thing you can do is install some dynamat on the inside too. And there's always a healthy stall converter to help get the car moving.
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Red_94Formula
Jan 22, 2015 12:17 AM
Jazsun
Dec 29, 2014 12:14 PM
