What symptoms with a bad MAF.
Old Jun 14, 2003 | 09:41 PM
96z's Avatar
96z
What symptoms do a bad MAF cause? I have no codes but the car doesnt respond to any MAF changes in LT1edit and has a slight bucking or miss from 1500-3000. What does this sound like?
Old Jun 15, 2003 | 12:37 AM
96z's Avatar
96z
I know someone here has had a bad MAF.
Old Jun 26, 2003 | 12:10 PM
96speed's Avatar
PDM - You ever figure out he problem?
Old Jun 26, 2003 | 01:30 PM
1997rblckSS's Avatar
Well I can tell you this, I had my car scanned with autotap last weekend, apparently my GMAF isn't working that I own.
Its making me run in Speed density mode of coarse leaving the pcm making educated guesses on how much air is flowing in trying to create the right A/F mixture.
The only thing that I saw is that it caused a lean condition according to the O2 numbers...I don't have the numbers with me at the office but I can post them later when I get home.
So I don't know what the symptoms of a "bad MAF" is but I do know what its like not to even have the MAF working . I know I don't get any stumbles what so ever and it pulls all the way up through the power band just fine. This is probably useless information but TTT for you anyways because I would like to know also.
Old Jun 26, 2003 | 04:21 PM
96z's Avatar
96z
Not sure yet Ryan, I havent gotten a scanner on it yet and I got a new code but Im not sure what it is yet.
Old Jun 26, 2003 | 04:33 PM
rskrause's Avatar
Moderator
Matt: I have an old on that I know works. No screen. If you want to try it, let me know.
Rich Krause
Old Jun 26, 2003 | 07:39 PM
96z's Avatar
96z
Cool, Ill let you know rich, my only basis of this suspiscion is from what Bob told me. He said the car didnt respond at all to changes to the MAF tables on the dyno.
A quick swap maybe worth a try.
Old Jun 26, 2003 | 07:45 PM
revtime's Avatar
I had an 88 IROC 350 and the MAF went bad on it, I pulled into work and backing into a space car starts sputtering and popping and running damn poor, could barely keep it going. Pulled the connector on the maf and bingo! check engine light and smooth running thanks to limp home mode. I bought a new (well reman) maf and all was cured.
Old Jun 27, 2003 | 01:13 AM
scoobysnax83's Avatar
you say "limp home mode" but a lot of guys have had positive results by disconnecting the MAF. I did and it seemed a little peppier, but that could be in my head....
KYWes
Jun 14, 2022 06:52 AM
asilomar244
Jul 12, 2015 05:53 AM
ducttape1975
Jul 10, 2015 06:29 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
