Rotors
Old Jun 27, 2003 | 12:46 AM
L32Camaro's Avatar
Question Rotors
I had just have a quick question about which rotors to buy for my Z. I don't want to buy a thousand $ system or anything like that just a good set of rotors. Probably Baers but just from looking around at tby and thunder they are about $350 for a set of 4 rotors. Just wondering if I should go for slotted ones or cross drilled or what not. I have no idea which are better I know the cross drilled stand out better, but anyhow any suggestions on what I should get and where from. Thanks.
Evan
Old Jun 27, 2003 | 12:50 AM
cocheese's Avatar
I also need some rotors, but don't want to get the high $ set. I would like to get some slotted for sure, maybe crossed drilled. Have you thought about upgrading them, the whole brakes i mean, or do you want to stick with the stock calipers?
Old Jun 27, 2003 | 01:07 AM
L32Camaro's Avatar
Just the rotors for now, I need new ones and I don't want stock ones so....I still have a lot of engine work needed to be done before I start spending money on advancing the braking to a whole new level.
Old Jun 27, 2003 | 01:29 AM
cocheese's Avatar
True, true. I think i will stick with you on that one ! I was just looking around on LS1speed.com for some. Found some decent priced ones, but don't know about the quality or how reputable the companies are. I guess just keep looking, and if you get some pretty soon let me know, and i'll do the same!
Ryan
93 RedBird
Nov 15, 2015 08:24 AM
HibachiZ28
Nov 6, 2015 12:53 AM
jayblev95
Sep 26, 2015 09:44 PM
Henson071
Sep 18, 2015 04:01 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
