What sealer?
Old Nov 25, 2003 | 06:56 PM
Xride's Avatar
What sealer?
For my cam install in a couple month I was talking with a buddy and he said not to use copper sealer, as its jsut silicon thats orange.... two things, is this true? and what should I use then?
Old Nov 25, 2003 | 07:18 PM
S.J.S.'s Avatar
I assume your talking about Ultra copper RTV by Permatex......But there is a copper spray. As far as the cam install, I used Right Stuff in a can for the intake plenum (kinda spendy) and gaskasinch on the timing chain cover. The timing chain cover don't even need anything though a lot of peole put them on dry as long as you torque it to specs and alternate. I liked the added insurance.
Old Nov 25, 2003 | 09:40 PM
96z's Avatar
96z
What are you looking to seal specifically?
Old Nov 25, 2003 | 09:59 PM
Xride's Avatar
I didnt know that what it was used for mattered
Its for a cam and header install.
Old Nov 25, 2003 | 10:49 PM
S.J.S.'s Avatar
Okay...depending on your gasket. I didn't use any sealer on my SLP's. Although I've heard of guys throwing some Ultra Copper on them. All you'll need is like I told you earlier. My brother in law always uses Ultra Gray on the intake manifold. Make sure you drop a good fat 1/4 in. bead on the thing and go about a half inch up the heads on each sides. Let the RTV sit for 15-20 minutes before throwing on the plenum.
Old Nov 25, 2003 | 11:46 PM
jasons93z's Avatar
It does matter. I would use the rtv "RED" silicone high temp.
Old Nov 26, 2003 | 01:16 AM
InjectedSS's Avatar
Re: What sealer?
Your friend is a homo. Use copper sealant on the front and the back of the block for sealing the intake, and then SPRAY your intake gaskets on both sides with copper spray gasket
Jeff1904
Jun 5, 2016 05:00 PM
ACE1252
Oct 18, 2004 11:18 PM
ibanez6rg
Jan 16, 2004 09:50 AM
ryaskovic
Sep 10, 2003 10:34 PM
