What sealer?
What sealer?
For my cam install in a couple month I was talking with a buddy and he said not to use copper sealer, as its jsut silicon thats orange.... two things, is this true? and what should I use then?
I assume your talking about Ultra copper RTV by Permatex......But there is a copper spray. As far as the cam install, I used Right Stuff in a can for the intake plenum (kinda spendy) and gaskasinch on the timing chain cover. The timing chain cover don't even need anything though a lot of peole put them on dry as long as you torque it to specs and alternate. I liked the added insurance.
Okay...depending on your gasket. I didn't use any sealer on my SLP's. Although I've heard of guys throwing some Ultra Copper on them. All you'll need is like I told you earlier. My brother in law always uses Ultra Gray on the intake manifold. Make sure you drop a good fat 1/4 in. bead on the thing and go about a half inch up the heads on each sides. Let the RTV sit for 15-20 minutes before throwing on the plenum.
Re: What sealer?
ACE1252
Oct 18, 2004 11:18 PM
