ARP thread sealer & assembly lubricant
Where can I pick up some ARP sealer and lubricant for my heads?
Also which bolts do you use each on (head bolts)? I know whatever bolts touch coolant get sealer and the others get lubricant. But which bolts touch coolant and which ones don't?
I put oil under each head to give a more smooth consistant torquing even though the ARP bolts came quite *greasy*. Yes, I did use the washers because the heads are aluminum. Although the stocker didn't use washers. But hey, what is it gonna hurt?
Oh...and one more thing. There's 3 different head bolt lengths. I'd highly suggest you keep up with which one goes where.
But like most people, they don't pay attention during the disassembly.
So, short bolts (see Chilton for head bolt numbers/sequence),
16, 12, 8, 4, 3, 7, 11, 15
Medium bolts.
14, 17
Long bolts,
15, 5, 2, 10, 9, 1, 6
There's a total of 17 head bolts per head.
Medium bolts.
14, 17
Long bolts,
Medium bolts.
14, 17
Long bolts,
Medium bolts.
14, 17
Long bolts,
