What PSI for street tires at the track?
Old Jun 26, 2003 | 06:04 PM
$hawn's Avatar
What PSI do you run street tires at, at the track, I'm talking about with no major weight reduction either, with typical track conditions.
Old Jun 26, 2003 | 06:17 PM
indy500ss's Avatar
If I remember right I was doing about 16-19 psi on some cheesy Pep Boys Futura's. At that psi was about the best hook I could get on street tires, definatly recommend slicks, or at least DR's.
Old Jun 26, 2003 | 07:14 PM
Sweetred95ta's Avatar
I ran 23 psi, and I hooked fine. Make sure if u go real low, u bring a plugin air pump.
Old Jun 26, 2003 | 07:54 PM
12SCNDZ's Avatar
I ran 24# in my Nitto Drag Radial...which pulled a 1.90 60 FT. I run 16# in my M/T ET Streets...which pull a 1.73 60 FT.
Frank
Old Jun 26, 2003 | 11:27 PM
$hawn's Avatar
Yeah I got those futuras on mine, they were on the car when I bought it, last time I went to the track it was like 50 degrees out and with the tires at 36psi and pulled a 2.30, so think i'll put them at like 30psi and with it going to be 89 for a high I think i'll see an improvement. what about the fronts, a little higher than normal?
Old Jun 27, 2003 | 12:55 AM
street demon2k3's Avatar
on my last run i went 13.8 with 25-28psi in the bald bfg's. they hooked real good all night long
Old Jun 27, 2003 | 05:24 AM
Patman's Avatar
I ran my best ET (and 60ft) with the tires at 30psi. Regular radials should not be run at less than 25psi, otherwise the tread cups and you get less traction. Only soft sidewall tires should be run at low pressure. (drag radials, ET streets, slicks)
Old Jun 27, 2003 | 06:04 AM
Smokn '94 Z's Avatar
Arrow
I used to run between 16 - 25 psi on my bfg comp ta's.... Was able to cut a 1.81 60' on them...
Old Jun 27, 2003 | 05:47 PM
Getsome17's Avatar
What kind of pressure are you guys running in your front tires???
DirtyDaveW
Mar 15, 2015 07:01 PM
Ken Cemo
Feb 13, 2015 08:37 AM
Ken Cemo
Jan 27, 2015 08:45 AM
vic_wants_an_SS
Jul 30, 2002 11:38 AM
ferraricameron
Jul 29, 2002 07:46 PM
