1LE suspension
Old Jun 27, 2003 | 04:28 PM
doodad's Avatar
Question 1LE suspension
Does anybody know if the 1LE suspension setup with the springs and shocks lower the car more than stock?
Old Jun 27, 2003 | 04:43 PM
RichJ's Avatar
1LE springs tend to raise the car, not lower it.
Old Jun 27, 2003 | 04:46 PM
FacelessZ's Avatar
Aren't the springs on 1LE's launch springs or am I just way off...
Launch springs aren't that expensive cause the manufacturer doesn't have to compress them as much...they're good for...um...launching
Old Jun 27, 2003 | 04:51 PM
doodad's Avatar
Thanks for the replies. I know they are progressive rate, but wasn't sure what they did for stance. I have gfx and am looking for no more than 1/2-1 of drop. And 1" makes me nervous with LT headers and the gfx.
Old Jun 27, 2003 | 04:56 PM
FacelessZ's Avatar
LT's won't hit...your Y-pipe will...
Old Jun 27, 2003 | 04:59 PM
doodad's Avatar
I stand corrected. You are right and they do. Now how about those springs?
Old Jun 27, 2003 | 05:07 PM
FacelessZ's Avatar
Performance Coil Spring lowers your car 1" for $229.99 off of TByrne....
Old Jun 27, 2003 | 05:10 PM
doodad's Avatar
You think if I got those and adj shocks I could "tune" the ride in case I scrape too much?
Old Jun 27, 2003 | 05:12 PM
FacelessZ's Avatar
Now that I couldn't tell you...no personal experience with it....anyone else?
I don't think you'll be having to worry about scraping with a 1" drop...not too bad anyways....
Old Jun 27, 2003 | 05:41 PM
RichJ's Avatar
Adjustable shocks won't let you adjust ride height unless they are threaded coilovers (like Hal QA1s). Also, the 1LEs are straight rate in the front (360 lb/in) and progressive in the rear (about 130-180 lb/in). If you want adjustable ride height, then you need to get something like coilovers from Ground Control ($400) or Global West ($$$). Do you want to lower your car or improve its handling? If you are looking for better performance, then you can go a long way with better shocks and bars and just leave your ride height/springs alone. I have 1LE springs on my car too keep ground clearance for my LTs (when my car was dropped an inch before I hit both the collectors and the y-pipe!).
Old Jun 27, 2003 | 05:51 PM
doodad's Avatar
Handling is not the problem I just want to try and get some of that wheel well space esp in the rear eliminated. Sound like I need to just leave well enough alone and put the money elsewhere. Between the gfx and exhaust and my driveway it is already a challenge. Thanks everybody.
Kinglouui
May 26, 2016 11:05 AM
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
force10
Jul 30, 2015 04:56 PM
SpeedJunkee
Jul 19, 2015 09:06 PM
