what problems have you EVER had out of your Lt1???....everyone post
Old Apr 15, 2006 | 07:57 AM
  #61
JohnD's Avatar
Re: what problems have you EVER had out of your Lt1???....everyone post
Pinion seal fixed under warranty. Clutch started chattering, pressure plate warped, probably from abuse of prior owner. Put in new LT4 plate and relined disk. Changed to Mobil 1 and subsequently developed intake leak ruining clutch disk. Took apart clutch and had disk relined after fixing intake leak. Severe overheat on the highway due to sudden failure of thermostat. Amazingly, no engine damage. Sudden water pump failure at about 70K due to unknown reason. AC compressor locked up at 72K. Other stuff-plugs and wires, rear disks, etc.is just normal wear.
Old Apr 15, 2006 | 10:57 AM
  #62
chas's Avatar
I just had the rear and front seals replaced on my 97 Z28 SS , both are still leaking! I found out i have a bad balancer on the front, and maybe the crank is bad causing the rear seal to leak again.
If it's a bad crank, i just as well build up the motor while it's apart, the engine has 67,000 miles.
Anyone ever hear of a crank problem with the LT-1?
Chas
Old Apr 17, 2006 | 07:07 AM
  #63
autoxr's Avatar
Bought my 94 with 28k miles last summer. The previous owner informed me it was going to be needing a clutch. The car now has 31k on it, and so far, this is what I've done to it:
Clutch, pp, t.o. bearing, pilot bushing, & flywheel resurfaced
radiator and upper & lower hoses
rear main seal
Both front wheel bearings
pinion seal
4 new rotors
Hawk HPS pads on all 4 corners
MSD Blaster coil (stock coil was ok, I just upgraded)
Problems I haven't gotten to yet:
Auburn lsd is shot
Bose CD player doesn't work
Still chasing a high-rpm miss
random backfire though intake on startup
PS pump whines like crazy
passenger-side window painfully slow
I think that's about it. That's enough for less that 4,000 miles of ownership.
Old Apr 17, 2006 | 03:27 PM
  #64
Grease's Avatar
I've broken rear ends twice, blown a 4L60E, burnt up 2 clutches when it was an M6, opti failure, coil failure, burnt plug wire but none of the above compares to last spring when I broke a connecting rod at 6900rpm. See why
http://www.geocities.com/greasemunke...neBlowup1.html
http://www.geocities.com/greasemunke...neBlowup2.html
http://www.geocities.com/greasemunke...neBlowup3.html
Old Apr 17, 2006 | 03:31 PM
  #65
6SpdLT1Z's Avatar
Fuel Pump
Thermostat
Power Window Motors
Previous owner did plugs n wires, 02's...
Old Apr 17, 2006 | 04:46 PM
  #66
chas's Avatar
Add two more leaks to my 97 LT-1 , leaking from the opti and water pump!
Chas
Old Apr 17, 2006 | 06:56 PM
  #67
jah1542's Avatar
EGR valve, ignition coil, fuel pressure regulator, intake elbow. 75k miles, no leaks, stock opti (knock on wood).
Old Apr 17, 2006 | 07:03 PM
  #68
etex95's Avatar
will find out whats wrong with mine tommorow
(i ended up having to replace plug wires and coil)
Old Apr 18, 2006 | 07:10 AM
  #69
94FormulaFbird's Avatar
I had to replace the shortblock the oil pump failed and i spun a bearing. So i put in a brand new shortblock
I had the heater core go bad and leak all over my carpet
I need to replace the blown speakers
My tranny is starting to slip
o2 sensors
power window motors
I've only put 15K miles on it since i've owned it and i've had all these problems but now its like a brand new car
Old Apr 18, 2006 | 09:26 PM
  #70
CCRJon's Avatar
battery - died after 6 years
rear main seal - started leaking about 80k
pinion seal - started leaking about 60k
fan control relay - broke @ 80k - car overheated all the damn time
thermostat - just replaced with 160 degree
clutch - replaced @ 90k
passenger siade catalytic convertor - I shook something loose after I put on my borla exhause and subframes. I had a shop near me cut it out and weld a catco in its place. I'm going to get a random technology y-pipe to replace it soon.
and the big issue
The oil pickup fell off of the oil pump into the oil pan. Now, if I make any hard stops or hard right hand turns, my oil pressure dumps to zero and the chech gages light comes on. After the car levels again the pressure goes back to normal and the light blinks off. This means that I have to jack the motor up, drop the K-member, and remove the oil pan only to place the pickup back on the oil pump. I bought a bracket from Jeg's that is supposed to make sure it does not come off again. What joy! I just haven't found time to do it yet. After I do this - I'm sure my motor will blow up. It's been used to working with the starvation problem - if I fix it - something bad will happen!!!! LOL!
Old Apr 30, 2006 | 09:12 PM
  #71
Heatmaker's Avatar
Advanced Member
Originally Posted by Maldo
Sent pm you have a life time warrenty on your wire set.
My biggest problem was the wires this guy sold me.
Old Apr 30, 2006 | 09:47 PM
  #72
matt65's Avatar
Opti Replaced 3 times within 6 weeks (lots of hell related to this, too much for me to type).
Clutch replaced at 102k
Also the Flywheel
Rear Main
Front Crank Seal
I will be replacing the trans and TA mounts soon along with the rear Tranny seal.
Old Apr 30, 2006 | 10:28 PM
  #73
Vigilante's Avatar
opti
2 waterpumps
2 rear ends
clutch @ 50k
2 window motors
intake manifold oil leak
currently leaking oil from front and rear main seals
almost forgot, the A/C has broken twice and its not getting fixed this time.
I don't even want to get into it about my last Z28.
Old Apr 30, 2006 | 11:04 PM
  #74
robb4964's Avatar
Originally Posted by 30AnvZ28
Ive successfully blown the entire drive train on my car... bone stock!!!! hahaha, so pick a problem
WOW! What do you do to your car? I drive mine hard and dont have to many probs.
LT1 Problems: Current 97: Leaky water pump,rear end makes noise,fuel pump.
95Zm6:50K miles with no trouble. Most reliable car I ever owned.
95Formy:Optispark,wheel bearing.
Old May 1, 2006 | 12:14 PM
  #75
street demon2k3's Avatar
2 years, 15k miles, 20+ track passes, lots of 1.7 60ft's and never had any problems with my car until i installed the cam in the stock shortblock(140k). first the alternator, then the opti which i denied until i went through 2 sets of wires and 3 sets of plugs. finally bought a new opti and then i spun like 3 bearings. so its been down for 8 months now, but a 355 is going in any time now.
so up til today i hate :
opti's
alternators
stock shortblocks w/ xe230/236.....LOL!!
oil pan gaskgets
driver side window motor
headlight motors
a/c that doesnt work in 100*+ texas heat
