What oil pressure is normal for an LT1?
Old Sep 17, 2007 | 04:10 AM
  #31
JustNO's Avatar
Originally Posted by rskrause
I am saying that if the oil pressure is 60pis cold and also 60psi fully warm, something is screwy. I suspect the gauge but I suppose it could be something else. What oil are you using?
Rich
I'm using 15w 50 dino oil. I have a "blue smoke" problem with my new engine (2000 miles). But I have used 10w 40 sysntetic and oil pressure was the same.
Old Sep 17, 2007 | 04:14 AM
  #32
rskrause's Avatar
Moderator
That is wierd. Maybe I am "blowing smoke"? Anyone else ever seen a car with the same OP cold and warm? What pump are you using? What pressure relief spring? Is the motor set up very "tight"? What I am getting at: is it pumping enough oil relative to the resistance that it is always bypassing, even at idle? In that case, the constant pressure is just a function of the relief valve.
Rich
Old Sep 17, 2007 | 04:21 AM
  #33
JustNO's Avatar
Rich
I couldn't solve the "blue smoke" problem. I will change the valve seals (came rubber ones with AFR heads). The engine was built at Thunderracing and it was built for a 200 shot nitrous. I didn't use nitrous, but I think the blue smoke coming from the rings? I'm using High Volume Pump with 6qt Canton oil Pan.
HectorM52
Jul 30, 2017 11:46 AM
Z28countrymama
Jan 22, 2015 02:50 AM
Jessie4tin
Jan 7, 2015 08:53 AM
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
