Happy Hooker question
Old Sep 12, 2007 | 01:14 PM
jhashba's Avatar
Guys,
I just got a Happy Hooker and I need to know if you have to remove the fuel rails to bolt it on or not. Do you just reuse the fuel rail bolts with the rails still on or do you take them off and then bolt on the Happy Hooker. The bolts that came with it will not go through the holes in the rails.
Jim Hashbarger
Old Sep 12, 2007 | 04:21 PM
Colin91Z's Avatar
Yes, you need to remove the fuel rails from the intake. And use the supplied bolts, they are grade 8 bolts. They factory bolts are not grade 8 and will probably not hold the weight if you try to use them.
Old Sep 12, 2007 | 08:15 PM
SnakeOiler's Avatar
I left my fuel rails on and used the fuel rail bolts to attach the hooker.
Old Sep 12, 2007 | 11:58 PM
tapout911's Avatar
I always remove the fuel rails and use the bolts supplied with the hooker. I have used mine several times over the past 2 years. Still using the same bolts that came with it.
Old Sep 17, 2007 | 02:02 AM
SS Joe's Avatar
Ditto. I have used mine 3 times so far.
Old Sep 17, 2007 | 02:23 AM
Irish350's Avatar
the hells a happy hooker?
(not including the obvious)
Old Sep 17, 2007 | 03:26 AM
SS Joe's Avatar
Its a lift plate made by TPIS specifically for LT1 F-bodies (drilled for the stock LT1 intake, as well as a couple 4 barrel patterns). Its a flat plate with a swiveling hook on it, designed to make it easier to pull the engine from the top. Works great!
http://www.tpis.com/index.php?module...l%2FTest+Equip.
Old Sep 17, 2007 | 09:55 AM
OBE1 95Z28's Avatar
Here you go: http://tpis.com/index.php?module=cat...y=Happy+Hooker
RUENUF
Mar 13, 2016 03:39 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
ChrisFrez
Jan 4, 2015 08:43 AM
ModdedNerd
Jan 1, 2015 10:56 AM
