What oil pressure is normal for an LT1?
Old Mar 2, 2007 | 06:31 PM
CALL911's Avatar
What oil pressure is normal to see in an LT1? Both at idle and under load.
What does everyone usually see in their LT1?
Old Mar 2, 2007 | 06:37 PM
LiENUS's Avatar
behold the power of shoebox LT1 Engine Specs
Many things come out of the shoebox, check it often.
Old Mar 2, 2007 | 06:43 PM
CALL911's Avatar
The power of the shoebox must be on a microscopic level, as it is too tiny to read even after blowing it up 30 times
Old Mar 2, 2007 | 06:47 PM
Jamon's Avatar
I can't tell you waht it should run, but I can tell you what mine runs and see if maybe you're higher or lower.
Upon start it's around 35-40 psi, and under load when cold it's at about 60-65.
Once it warms up it drops off. about 20-30 at idle, and 45+ at WOT.
Hope that helps.
Old Mar 2, 2007 | 06:53 PM
LiENUS's Avatar
Mines approx what jamons is, shoebox's website says 6psi minimum at 1000 rpm 18 psi minimum at 2000 rpm and 24 psi minimum at 4000 rpm and torque your oil filter down to 15 ft lbs
Old Mar 2, 2007 | 07:02 PM
CamaroSS30thAnn's Avatar
15-20ps1 HOT idle 50-55 under load
cold start up around 50-55 slowly goes down as car warms up
sometime when its really hot out it might hang around 10psi
thats with mobill 1 syntec 5w-30 and 85k....i prolly could use a thicker oil
Old Mar 2, 2007 | 08:39 PM
Critter's Avatar
75 cold
35 idle warm
and 80 at 6700
Old Mar 2, 2007 | 08:52 PM
Ricardo's Avatar
50 cold start idle
25 idle hot
45 all the way from 2000 to 6500 RPM hot
standard volume stock pump
RG
Old Mar 2, 2007 | 10:52 PM
You must have a computer problem.
Old Mar 3, 2007 | 06:40 AM
CALL911's Avatar
I'm pretty confident my computer is fine. The page for a split second actually is large, but then instantly it shrinks in size to a microscopic level. It's probably just a default setting my computer is at or something :blah:
Old Mar 3, 2007 | 08:50 AM
moparman's Avatar
Shoe's site works just fine for me.
On a cold start, oil pressure is around 65 lbs. Hot idle is around 35 lbs. At 60mph it's around 50 lbs. Using German Castrol 0W30 with the long Wix filter.
Old Mar 3, 2007 | 09:32 AM
Your computer is not fine. I was not really referring to hardware. There is something on it causing the issue. Turn off automatic image resizing if you are using IE.
Old Mar 3, 2007 | 10:27 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
If IE is automatically resizing the image, putting your cursor over the image and left clicking your mouse should expand the image back to it's original size.
Old Mar 3, 2007 | 10:51 AM
rskrause's Avatar
Moderator
25-35 psi at warm idle is pretty high for a gen I or II SBC. Much higher than needed, that's for sure. Engines running that high are either set up too tight or have a bigger oil pump than needed. Either costs hp and causes other potential problems. You should see that on high an oil pressure at idle only you are running a very heavy oil, for some reason. I look for 10-20psi at warm idle depending on the oil used and the old rule of thumb of 10psi/1000rpm is a good one.
Rich
Old Mar 3, 2007 | 03:55 PM
kline454's Avatar
im running 60 cold start, hot idle in gear 30psi, hot @ 4000rpm=65-70psi, on 10w30,
