What oil pressure is normal for an LT1?
Old Mar 3, 2007 | 03:59 PM
  #16
MTL_Z28's Avatar
55 psi cold idle
25-30 psi warm idle
on the autometer mech. gauge
With Castrol GTX 10w40, K&N HP2002, stock oil system.
Old Mar 3, 2007 | 10:34 PM
  #17
STREETLETHALZ's Avatar
mine's 16 @ hot idle with 10W30 castrol
it gets around 40ish when it's up there in the Rs, but i pay less attention to that than the track...
Old Mar 3, 2007 | 11:14 PM
  #18
rskrause's Avatar
Moderator
Sounds to me like a lot of you could be using a lighter oil and making a few free ponies.
Rich
Old Mar 4, 2007 | 07:54 AM
  #19
CALL911's Avatar
Rich
What do you reccomend Rich?
Old Mar 4, 2007 | 10:14 AM
  #20
rskrause's Avatar
Moderator
I'd run 5W-30 or maybe even 5W-20 if I saw pressure as high as some of you are seeing. I prefer slightly loose clearances and a heavier oil for myself though.
Rich
Old Mar 4, 2007 | 10:24 AM
  #21
BrokeMofugga's Avatar
Originally Posted by BTC
If IE is automatically resizing the image, putting your cursor over the image and left clicking your mouse should expand the image back to it's original size.
This works for me,
Old Mar 4, 2007 | 10:44 AM
  #22
CALL911's Avatar
Originally Posted by BrokeMofugga
This works for me,
It didn't for me.
Old Mar 4, 2007 | 11:08 AM
  #23
94Z28WP's Avatar
Do what Shoebox said:
Tools>Internet Options>Advanced tab>Uncheck "Enable Automatic Image Resizing">Apply.
Mine runs at just below 20psi at hot idle.
Old Sep 15, 2007 | 10:45 AM
  #24
JustNO's Avatar
This kinda old thread, but my oil pressure is 60 psi at cold and 60 psi at warm idle, doesn't matter if its cold or warm, its stabile. At WOT It reaches around 75-80psi. Is it normal?????
Yes I'm using HV Oil Pump with 6q Oil Pan.
Old Sep 15, 2007 | 01:15 PM
  #25
neal38's Avatar
was 40 cold then below 20 hot but changed the sensor (pain in the rear) now its 65 cold and 30 hot these are idle pressures ( stock 97 Lt-1 97,000miles)
Old Sep 15, 2007 | 08:46 PM
  #26
rskrause's Avatar
Moderator
That sounds like a bad gauge. There is no way the pressure should be the same hot as cold. Do you mean "warm"" when the water temp gauge is in the operating range or do you mean when the motor is fully warm? The water temp will reach operating temp very quickly. It takes up to an hour of street driving for the oil to reach a steady state. Cold oil temps mean next to nothing.
Rich
Old Sep 16, 2007 | 05:18 AM
  #27
JustNO's Avatar
Rich
Wow It takes 1 hour ?? I never drive 1 hour except I stuck in traffic. Hmm I want to test this then. I'm pretty sure my oil pressure is always at 60psi at idle. But If it goes to 75-80psi at WOT this means my gauge is working right??
Old Sep 16, 2007 | 08:20 PM
  #28
rskrause's Avatar
Moderator
I am saying that if the oil pressure is 60pis cold and also 60psi fully warm, something is screwy. I suspect the gauge but I suppose it could be something else. What oil are you using?
Rich
Old Sep 16, 2007 | 08:38 PM
  #29
Kaj's Avatar
Kaj
I'd like to use a lighter oil, I'm currently using Mobil 1 5w-30 synthetic what would be my best bet to go with?
Old Sep 16, 2007 | 09:29 PM
  #30
Zeueses 97 RamAir's Avatar
Diffrent
Some cars are diffrent on a cold cool day mine is above the first line which, I have been using synthetic forever on that car.
