What "gremlin" caused your H/C power loss?
Old Aug 24, 2006 | 09:12 AM
  #16
JakeRobb's Avatar
Super Moderator
Re: What "gremlin" caused your H/C power loss?
Originally Posted by onefastgta
I'm interested in knowing also, as I'm trying to find the gremlins in my combo.
I don't know if I agree with what you said about the A4 with stalls being a reason for low dyno numbers and validating it at the track though, with my 366 rwhp and 350 rwtq and a 3750lb car, I can only get a 12.77 at 107 out of it with a 1.71 60ft, so there is another 'gremlin' or 'gremlins' to be found.
Was it hot at the track? If so, your numbers are pretty good. I'm not saying there's nothing wrong, but you're getting out of the hole pretty fast, and sometimes that can hurt trap speed.
If it was hot, I'd try it again on a cooler day before you get too upset about those results.
Old Aug 24, 2006 | 09:32 AM
  #17
onefastgta's Avatar
Not hot, it was November, maybe 50-60 degrees? I'd have to check and see if the timeslip has the temp on it.
Plus, you are trapping the same mph as me with no mods to your 2002, so something is wrong.
Either way, it still sucks. There are others making less power and running 3-4 mph faster, and similar combos as mine running 117-118 mph.
Old Aug 24, 2006 | 09:38 AM
  #18
JakeRobb's Avatar
Super Moderator
I think I'm putting about 315-320 to the ground (never been on a dyno, just guessing), and my car is lighter than yours. Those internet horsepower calculators tell me I'm making ~345, but I'm sure it's not that high.
Your 60' is 0.4 seconds faster than mine. It's common for improvements off the line to translate to lower MPH through the traps.
Like I said -- I'm not saying that I know for sure that there's nothing wrong with your car -- just that I think whatever is wrong is pretty minor.
Old Aug 24, 2006 | 09:44 AM
  #19
user 647483's Avatar
Jake, (EDIT: Sorry that should have been "onefastgta")
you'd probably be more likely to get feedback and assistance with a
seperate thread. I started this one to collect a list of solutions form people
who have already resolved their power issues.
Old Aug 24, 2006 | 09:50 AM
  #20
JakeRobb's Avatar
Super Moderator
Originally Posted by James Montigny
Jake,
I was giving feedback and assistance to someone else.
Details aside, sorry for jacking your thread.
Old Aug 24, 2006 | 09:59 AM
  #21
Old Aug 24, 2006 | 10:25 AM
  #22
truedualws6's Avatar
Specifically, what was the issue with OBDII ?
And yes, the correct solution is usually the last one you check LOL
(kinda like searching for car keys)
It's best described by the dyno graph. OBDI / OBDII Dyno Graphs
I have no idea what was going on. The tuner (Jeff Creech) was not sure either,
but I'm gald he suggested trying the OBDI PCM.
Old Aug 24, 2006 | 10:27 AM
  #23
LOL, ok so you did a wholesale conversion to OBDI.
I've heard of a few people making that change.
Old Aug 24, 2006 | 02:32 PM
  #24
snakeatinZ's Avatar
Originally Posted by wrd1972
Take a screwdriver and bang on your MAF, if it affects the idle then the MAF needs to be replaced.
Hillbilly mechanicing
Old Aug 24, 2006 | 03:13 PM
  #25
Mikey97Z's Avatar
Originally Posted by turbo_Z
Sucking oil from the lifter valley was a problem for me and a friend in our builds. I think mine may still be doing it too...
I had bigtime problems with this. An internal vacuum leak somewhere, and it was pulling in air and oil. I tried reinstalling my intake a few times, but the leak always came back.
Old Aug 24, 2006 | 03:46 PM
  #26
Was that something you could hear?
Or was there a different way to diagnose that?
Old Aug 24, 2006 | 05:31 PM
  #27
turbo_Z's Avatar
I bet this problem is far more common then people think. My next move is to go with the real thick felpro gaskets and use silcone again.
REDNECKISBOSS
Mar 22, 2015 08:31 AM
robcarnut
Mar 20, 2015 03:40 PM
grabbem88
Mar 18, 2015 01:25 PM
thenewkid
Nov 27, 2014 09:41 AM
XtremeLt1
Sep 13, 2002 08:50 PM
