Anyone used the ngk o2 sensor?
Old Jun 29, 2006 | 06:58 AM
onetransam4u2nv's Avatar
I was just lookin thru summit and i see they have ngk o2 sensor's. i heard of some guys havein problems with other brands.I f you have used these with any luck let me know. thanks
Old Jun 29, 2006 | 08:16 AM
anaik's Avatar
Re: Anyone used the ngk o2 sensor?
If you have heard of problems with other brands, why not get the AC Delco?
Old Jun 29, 2006 | 09:11 AM
contraststriker's Avatar
Because they're expensive as hell. The lowest I've ever found them was $42 but I lost my bookmark to the deal...I am also interested in this Q.
Old Jun 29, 2006 | 09:45 AM
OffspringZ28's Avatar
www.rockauto.com
jsetzer's Avatar
I put a set in 2 weeks ago and so far so good. They read right and my blms set right around where they should be.
Gas mileage has improved also.
I see no problem with them.
Old Jun 29, 2006 | 10:32 AM
anaik's Avatar
Try these one of these wholesalers. They are about the cheapest for GM parts, and the shipping is within bounds.
http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
Old Jun 29, 2006 | 04:54 PM
matt65's Avatar
...I would only use AC Delco.
Old Jun 30, 2006 | 12:22 AM
JJJ93z's Avatar
im running ngk single wires from a 93 LT1 Vette in mine, and they seem to be fine, im getting my tune from Ion soon so i will let you know for sure then.
Old Aug 24, 2006 | 07:19 PM
RRR's Avatar
RRR
I too have looked into using them. Not sure if they are better than factory ac delco. Anyone else have info/experience with the ngk's?
Old Aug 24, 2006 | 08:50 PM
Honda Hunter's Avatar
Does yours take longer to warm up due to the Longtubes?
Slayer
Aug 17, 2015 03:55 PM
BMX Dad
Aug 15, 2015 01:15 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
