what do you think i will put down to the ground
Old May 21, 2006 | 10:28 PM
camaroz2866's Avatar
tryin to figure out what i will be pushing after this
LT1 Block Bored .030 Over And Clearanced for Stroker Crank
Eagle ESP Forged 4340 3.75" Crankshaft
Eagle ESP Forged 4340 5.7" Rods
Speed-Pro Forged 4.030 Pistons
Speed-Pro Plasma Moly Piston Rings
Lloyd Elliott LE2 383 Cam
Lloyd Elliott LE2 Ported heads
Victor Jr. Single plane Conversion with Aeromotive Fuel rails and custom elbow
Comp Chromoly Pushrods
Comp "R" Lifters
Comp 977 Valvesprings
Comp Titanium Retainers
Comp ProMagnum 1.6RR's
Moroso high Volume Oil pump
Spec Stage 3
Jennings Engineering Built T56
Aluminum Driveshaft
Walbro 255 w/ Racetronix wiring harness
MSD Digital 6
MSD Coil
MSD Wires
New GM replacement OPTI
Mezeire EWP
SLP CAI
AS&M 58mm TB
Pacesetter LT's
3 inch Y-pipe to 3.5 inch exhaust back
SLP 2OTL
DMH 3.5" Electric Cutout
Every Single bolt is being changed to ARP
Old May 22, 2006 | 04:14 PM
toby's Avatar
Re: what do you think i will put down to the ground
not sure what your compression is but 440 rwhp and 420 rwtq.
Victor Lamb
Aug 26, 2017 02:52 PM
PCLZ28
Dec 24, 2015 05:19 PM
blac94Z
Mar 20, 2015 09:58 PM
eazyZ
Mar 1, 2015 07:12 AM
Injuneer
Dec 15, 2014 09:36 AM
