what do you think i will put down to the ground
tryin to figure out what i will be pushing after this
LT1 Block Bored .030 Over And Clearanced for Stroker Crank
Eagle ESP Forged 4340 3.75" Crankshaft
Eagle ESP Forged 4340 5.7" Rods
Speed-Pro Forged 4.030 Pistons
Speed-Pro Plasma Moly Piston Rings
Lloyd Elliott LE2 383 Cam
Lloyd Elliott LE2 Ported heads
Victor Jr. Single plane Conversion with Aeromotive Fuel rails and custom elbow
Comp Chromoly Pushrods
Comp "R" Lifters
Comp 977 Valvesprings
Comp Titanium Retainers
Comp ProMagnum 1.6RR's
Moroso high Volume Oil pump
Spec Stage 3
Jennings Engineering Built T56
Aluminum Driveshaft
Walbro 255 w/ Racetronix wiring harness
MSD Digital 6
MSD Coil
MSD Wires
New GM replacement OPTI
Mezeire EWP
SLP CAI
AS&M 58mm TB
Pacesetter LT's
3 inch Y-pipe to 3.5 inch exhaust back
SLP 2OTL
DMH 3.5" Electric Cutout
Every Single bolt is being changed to ARP
Comp "R" Lifters
Spec Stage 3
Aluminum Driveshaft
MSD Digital 6
MSD Coil
MSD Wires
Mezeire EWP
SLP CAI
AS&M 58mm TB
Pacesetter LT's
SLP 2OTL
Victor Lamb
Aug 26, 2017 02:52 PM
