View Poll Results: Which camshaft?
Crane 227
12.50%
cc503
12
37.50%
"466 xfi"
25.00%
Lunati 60121
9.38%
Other
15.63%
Voters: 32. You may not vote on this poll
What DD camshaft?
Old Dec 28, 2007 | 03:53 PM
  #31
ABA383's Avatar
SS RRR beat me to it...the LPE 211/219 is a great DD cam...I had it in my 383 and it trapped 115-117...
--Alan
Old Dec 28, 2007 | 04:15 PM
  #32
reamo04's Avatar
okay, its between the 466 or the 503 since i can get either for 190-210 with my discount...the others i cant get anything less than 300. Out of those two, which ones guys?
Old Dec 28, 2007 | 06:03 PM
  #33
96capricemgr's Avatar
Originally Posted by slomarao
there was a thread about 8 weeks ago of a cam only 94z that made 359/349to the tires. Is was a AI custom 234/242 or something, i would look into a custom cam with your goals. Get one from bret or somebody around here, they wont steer you wrong.
I want to say the cam you are trying to quote was closer to 10 degrees SMALLER than you are claiming here.
114mph is high 11s for a street car that hooks well.
A more dedicated race car might actually get an 11.6 with 114mph but high 11s very low 12s is more realistic.
Old Dec 28, 2007 | 06:08 PM
  #34
reamo04's Avatar
well guys, with the dart pro-1s i should be able to get 11's with the 466 cam
https://www.camaroz28.com/forums/sho...ghlight=268xfi
370/350 at the wheels, not too shabby.
Is the cc503 capable of that or not?
Old Dec 28, 2007 | 09:19 PM
  #35
Z-RATED94's Avatar
Those are the same #s my cam and set-up came up with through a 2800 Vig. With the Yank SS3600 it dynos at least 10 hp less.
Old Dec 28, 2007 | 09:43 PM
  #36
reamo04's Avatar
was that w/ the 222/226, or a diff cam?
Old Dec 28, 2007 | 09:48 PM
  #37
reamo04's Avatar
http://youtube.com/watch?v=TcB-Jc3RSdA
thats the "466" cam, i think it sounds good. Im going to run a "desktop" dyno with a few different setups, and see what one comes out the way i want it to, and i'll let you guys know what i decide on
Old Dec 28, 2007 | 09:54 PM
  #38
dangalla's Avatar
why not just port the stockers, flow better and you can spend the extra money you saved on a much better custom cam
Old Dec 28, 2007 | 09:58 PM
  #39
speed_demon24's Avatar
My vote is for the Crane 227, I went 115mph with that cam with valve float and a tune in the mid 11's a/f wise. Heads only flowed ~240cfm too.
Old Dec 28, 2007 | 10:07 PM
  #40
reamo04's Avatar
because, i only plan on running this setup for a year or so, i am then going turbo
Old Dec 29, 2007 | 08:03 AM
  #41
Z-RATED94's Avatar
The 222/226. It will be at least a year or so before I move up a notch with cams.
Old Dec 29, 2007 | 08:04 AM
  #42
antne194's Avatar
Additional cubes?
How would additional cubes, such as 396, change your cam choices.
I am looking for a DD with nitrous with a4.
Does anyone know of a good set-up?
Thank You
Old Dec 29, 2007 | 08:10 AM
  #43
dangalla's Avatar
dont jack someone elses thread, please start your own it will really reduce confusion, and a search should help out alot this has been gone over alot in the past
Old Dec 29, 2007 | 09:22 AM
  #44
antne194's Avatar
I apologize and stand corrected. Thank You
Old Dec 29, 2007 | 09:58 AM
  #45
reamo04's Avatar
Thank You
i'll help ya out here as much as I can
Additional cubes will lower the powerband, and make a larger cam idle more smoothly, i.e. like a smaller cam in less cubes.
With the additional cubes, you can use a bigger cam.
Thats the main gist of it.
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
