Oily Spark Plug?
Old Dec 28, 2007 | 04:32 PM
eagleknight97's Avatar
Oily Spark Plug?
Alright, what would cause a spark plug to look like this
All the other plugs look normal, no oily residue on them. This plug is on the drivers side. Its clean where the boot goes but oily between the boot and the block. I was going to take it out and look at it but I dont currently have a spark plug socket.
Old Dec 28, 2007 | 05:18 PM
MyShibbyZ28's Avatar
The rings might be seaping oil slowly and that might be leaking through the threads on the plug. Hard to tell if you don't take the plug out. Once it's out, stick you're finger in there and feel around, if you have oil on your finger thats bad
Old Dec 28, 2007 | 05:22 PM
C5042081's Avatar
valve seal or ring usually makes oil on the inside of the plug, is the plug loose?
Old Dec 28, 2007 | 09:56 PM
Wild1's Avatar
I wish I had a clean shot of my plugs like that! Pull the plug, is it oil fouled?
Old Dec 29, 2007 | 01:17 AM
Id pull it if I had a socket, but my socket set is back at my apartment and im at my parents house for another week and my dad doesnt have a spark plug socket.
Old Dec 29, 2007 | 12:18 PM
Built LT1's Avatar
I'm going through something similar to this, my rings were in fact washed.
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
