What Damper?
Old Apr 7, 2012 | 12:04 PM
Black 97 SS's Avatar
What Damper?
Hello I am looking to put a ATI Super Damper on my Camaro.
I have a 95 shortblock with 97 accessories on the front. I believe that the balancer hubs changed between the two year? When I order the damper which year should i order for? I think 95 but I would like to comfirm.
Also what size should I go with for best performance? I dont have a aftermarket radio so charging is not a issue. These part numbers are from Summit Racing:
6.750 in. ATI-917271
6.780 in. ATI-917272
7.500 in. ATI-917268
7.530 in. ATI-917270
Thanks,
Jason
Old Apr 7, 2012 | 12:28 PM
96capricemgr's Avatar
Re: What Damper?
You have a raised idle for the cam and deeper gears so engine rpms are up all over from stock so charging wont be an issue, I would go small.
Far as the year parts the difference is the 96-7 hub is slightly shorter to make room for the CPS reluctor, the accessory depth is far as I know the same. So what hub you need depends on if you are running the CPS reluctor or not.
Old Apr 7, 2012 | 12:41 PM
Re: What Damper?
Ok that makes sense, I am running the CPS reluctor since i retained the OBD II. So i will go small diameter for the 96-97 cars.
Thanks for your help.
Jason
Old Apr 7, 2012 | 01:21 PM
Re: What Damper?
I thought the ATI came with the short hub for the CPK cars, and a spacer for the non-CPK cars. But I bought mine 12 hears ago, and they might have changed.
If you plan to run high RPM, it would be an advantage to keep the accessory drive RPM's down.
Old Apr 7, 2012 | 01:48 PM
Re: What Damper?
I believe they still come with the spacer from what I have been reading today. Sounds like one hub fits all years +/- the spacer. I run the motor up 6600 and the limiter is set at 6800.
Do you think I should run a larger diameter for that RPM?
Thanks,
Jason
Old Apr 7, 2012 | 02:46 PM
Re: What Damper?
A larger diameter spins the accessories faster. You should use the size closest to stock, or the next size smaller. A smaller pulley slows down the accessories.
Daluchman1974
Sep 11, 2015 06:12 AM
shwine617
Advanced Tech
Mar 19, 2004 07:09 PM
LameRandomName
Advanced Tech
Dec 25, 2003 07:41 PM
JSK333
Sep 15, 2003 06:32 PM
Arctic_White_WS6
Advanced Tech
Nov 3, 2002 11:01 PM
