Fault code 36
Old Apr 7, 2012 | 03:18 PM
Nickw059's Avatar
Fault code 36
Well too start off... Every once and a while (Couple on months) My SES would pop on and my car would sputter for a second than it would go away. otherwise than that my car runs great! I finally have gotton datamaster to connect too my car, and its saying my car has dtc 36 high res but i dont have a SES light on. all the threads i've read people with this dtc their car runs and dies or doesn't run good, but mine does, any thoughts?
Old Apr 7, 2012 | 04:31 PM
Re: Fault code 36
DTC 36, for the high resolution pulse signal from the cam position sensor in the Opti does turn on the SES light, according the to GM shop manual. The engine can run without the signal, using only the low resolution signal, with a very minor loss of spark timing accuracy. That's on complete loss of the high res signal. If the signal becomes erratic, the engine RPM can become unstable.
The code could be a "stored" code, set when the SES light came on previously. The code will stay stored unless you clear it, or the vehicle is driven a certain number of "drive cycles" without the problem recurring.
Clear the codes by pulling the "PCM BAT" fuse for 30 seconds and see how fast it comes back. In the 94's the PCM BAT fuse is in the panel at the end of the dash.
markzzzz
May 8, 2015 09:21 AM
May 1, 2015 01:14 PM
91Bird305
Aug 8, 2002 12:36 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
