What Can I Do to improve my brakes?
Old Apr 28, 2003 | 10:46 AM
  #16
Severous01's Avatar
plus, noone knows this, but you cannot...repeat: can not have the drilled or slotted rotors turned. so if you do warp them, like i have now, you are out of luck. when they warp, you know it better than a solid rotor too. i have such a serious vibration from each slot hitting the pads unevenly that my cd player skips between 55 and 40 mph. sucks bad, but soon im getting the c5 calipers and stock rotors with ebc pads. found a place that sells the calipers for 75 a piece.
Old Apr 28, 2003 | 11:05 AM
  #17
GreenZ28in503's Avatar
I got the performance brake package from Thunder Racing (about 600 after shipping). Came with 4 Powerslot rotors, Hawk pads and steel brake lines. The kit really improved my stopping power, mostly due to the steel lines I think.
Old Apr 28, 2003 | 11:36 AM
  #18
gstaehle's Avatar
I have to agree with Dr. Mudge. Although I replaced my front rotors with the Power Stop and pads with VGX, I believe the SS hose kit made the biggest difference. They cost me $109.29 (last year) S & H included. Try the hoses first then build from there.
Old Apr 28, 2003 | 12:13 PM
  #19
Dr.Mudge's Avatar
Look for WS6_Keith in the nitrous forum (moderator), he's has some experience with cryoing his drilled rotors, I believe he said they last approximately 1/4 the time of a normal rotor even under street driving, without the treatment.
http://web.camaross.com/forums/priva...ge&userid=2597
keith@ws6.com
Old Apr 28, 2003 | 12:20 PM
  #20
thermwood1's Avatar
Actually Severous01 you can get the slotted rotors turned. You will just have to find a machine shop in your area that will turn them. Neither Autozone or Pep Boys can do this, but some machine shops can. It's basically the same price as it would be for regular rotors. I think mine were like $.50 more each.
I have the baer kit on my car with stainless lines and it works great. Definately worth the money. IMO.
Old Apr 28, 2003 | 12:31 PM
  #21
gb95zconv's Avatar
Originally posted by Dr.Mudge
Steel brake lines, and better than stock pads in front - steel lines RULE
Good point.....I left that out...I do have SS lines also.
Old Apr 28, 2003 | 01:23 PM
  #22
chasmanz28's Avatar
so yr saying to stay away from these types of rotors then, just buy the stock or soild types of rotors, that would suck to buy the drilled or slot types, and then they cant be turned, the only reason i wanted to buy them was because they look neat on the car, but now after reading this thread ill buy the stock version's
Old Apr 28, 2003 | 03:44 PM
  #23
lt4 fd's Avatar
So how well would the c4 brakes work with the grand sport calipers, has anyone done this and how is that the bear track kit or what ever??
Old Apr 28, 2003 | 03:46 PM
  #24
Severous01's Avatar
the c4 brakes dont even compare to the ls1 brakes. if you upgrade, get the bear gt brakes, or the c5 brakes. they are basicly the same...pbr dual piston caliper, 13" rotor, and cheap pads, even the brackets(upgrading from stock lt1 brakes) are the same in design. id get the c5 calipers
Old Apr 28, 2003 | 03:53 PM
  #25
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Originally posted by Fatdog
Cross drilled,great if you are going over 160mph,and need to stop better(heat thing).Factory pads seem to work better than after market.Coors beer is better than Milwalkii.Bud is better than Canadian beer.Depends who you talk to.Actually the factory stuff works very well(depends on the driver to).My02
uhhh
those holes are NOT for cooling nor do they aid in cooling
IRrocdreamer-
Hit meup on aim tonite and i'll talk to you about it... lots of cool free stuff you can do
I'm leavng work now...
Old Apr 28, 2003 | 04:23 PM
  #26
95 Z/28 LT1's Avatar
Super Moderator
You can get the required parts directly from GM. They have them in the Performance Parts Catalog. It allows you to bolt up the '96 Vette brakes to the Fbody.
Aug 24, 2015 06:41 AM
Boss002
Jul 24, 2015 10:47 AM
asilomar244
Jul 12, 2015 05:53 AM
Boss002
Jul 9, 2015 03:33 PM
