CC promagnum rockers and stock valve covers
Old Apr 26, 2003 | 12:14 PM
BigDaddy's Avatar
Anyone have problems with the adjusting nut on the stud hitting the top of the stock valve covers? I tweaked the centerbolt supports, so that the valve covers would go on, but they seem to be hitting the adjusting nut of my Promagnum roller rockers. What is everyone else using for valve covers?
Old Apr 26, 2003 | 12:26 PM
The nuts should not hit the valve cover. What I would check is that you did not put any of the rockers in with the fulcrum upside down. There is a top and a bottom. The top is machined out to let the nut fit inside. If you have it flipped over, the nut will stick up more. It should be easy to tell if any are upside down, by the amount the allen lock is turned in. If there are any that are turned in appreciably more than others, they would be suspect.
Old Apr 26, 2003 | 01:22 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: CC promagnum rockers and stock valve covers
no problem with mine
Old Apr 26, 2003 | 03:43 PM
atljar's Avatar
Ditto what shoe said.
If you rotate the arm 180 degrees, while holding the center section, you will see that they are different . One side is countersunk a little so that the jam nut sits into it, the other just has the samll hole. You want the countersunk hole facing upwards
Old Apr 26, 2003 | 03:58 PM
Javier97Z28's Avatar
Moderator
correct..
also when we did the install my friend clipped a bit of the support arms of the centerbolt guides with a dremel for clearance...
Old Apr 27, 2003 | 09:29 PM
BigDaddy's Avatar
thanks guys. The rockers are all on right. I haven't tightened them down yet, so I suspect that is the problem. I just figured that even after they are tightened, they would still be really close to the top of the valve cover. I wondering if I could use stock valve covers, or if I should get taller ones. As to the centerbolt supports, I just flattened out the portion that was hitting.
Old Apr 27, 2003 | 11:36 PM
RAMIN 94 TA's Avatar
I bought some LT4 valve covers, bolt right on in with out any mods. they clear my Promagnum roller rockers without any problems.
just my .002
Old Apr 28, 2003 | 12:15 AM
LT1ponykilla's Avatar
What is the cheapest place to buy the pro magnum rr's?
Old Apr 28, 2003 | 11:56 AM
atljar's Avatar
www.ftforce.com is by far the cheapest. Only thing is that i have read that their customer service is HORRIBLE.
What i did was have another company price match them. (tons of companies will do this (ie ls1 speed, tbryne, etc))
Old Apr 28, 2003 | 12:05 PM
Got my Pro Mags from Combination Motorsports (known for their awesome customer service) and were cheaper than the above mentioned "cheapest" place.
[edit] oops, I take that back. The 7/16ers were not as cheap. I bet they will price match, though.
Old Apr 28, 2003 | 12:08 PM
mobleman's Avatar
Combination Motorsports here as well. Awsome customer service!!!
Old Apr 28, 2003 | 12:12 PM
Even after surgery to the 1/2 of each center-bolt web support, I had some very light tapping on the stock valve covers. Just needed the usual "light whacks with a hammer" cure - not even visible from the outside. Not sure if it is related to the amount of lift... I'm close to 0.600" gross.
Old Apr 28, 2003 | 12:29 PM
95CamaroZ-28's Avatar
I'll never purchase from RaceNet One again. I bought the majority of my cam/valvetrain setup from them, but as it was previously mentioned, their customer service is terrible. I still have a set of Crane lifters sitting around that took them 3 months to get to me. I called and e-mailed numerous times to cancel the order for the lifters and was never credited back. Then after I have purchased a set of Comp lifters elsewhere, put the motor together and in the car, and broke the motor in, I finally get the lifters. I didn't want to deal with them any longer so I just kept the lifters.
I have the Pro Mags with my stock valve covers. I modified the center supports, but have had no trouble hitting anywhere else.
Old Apr 28, 2003 | 02:02 PM
treyZ28's Avatar
i wish i woulda bought more of my stuff from combo-
every fuxing day some moron would send me a wrong part and deny responsibility (ie racenet)
customer service is worth its wieght in cubic inches
Old Apr 28, 2003 | 02:17 PM
Whats the web sight for Combination Motorsports ?
