What is the best LT1 Timing set for the money??
Old Jul 19, 2007 | 08:54 PM
  #46
djk19's Avatar
how expensive are those pro gear setups? I paid 80 somthin bux for my cloyes billet double roller.... should do the trick nicely... if those progears are $200 then it is a lot like the comp cams which is awesome quality but if I get somthing billet and half the price... newer then stock .... then I am ok. ..
Old Jul 19, 2007 | 09:25 PM
  #47
SStrokerAce's Avatar
$90 or so. It's not about the billet but how they make it.
"Why Are Our Parts Different? (and better)
We are surprised at how many brands are out there selling so called "high performance
timing sets" with crankshaft sprockets that not even hardened. Some are just virgin steel
and some have the appearance of being heat treated, but are not actually hardened.
Some are powdered metal.
Progear crankshaft sprockets are made from 1141 steel and are all hardened to 50 Rc.
But we wanted to be better. On the 3000 and 4000 series not only is the crank sprocket hardened,
the camshaft sprocket is heat treated as well.
We also saw that the other sprockets being sold were full of razor sharp edges. Viewed through a
jeweler's loupe these sprockets are full of hanging burrs, many of which will end up in the oil pump.
All Progear sprockets are vibratory tumbled. All steel sprockets are hand filed and then vibratory
tumbled twice--once before heat treat and again after heat treat. This knocks off any hanging burrs,
eliminates sharp edges and removes heat treat scale. It also peens and work hardens the surfaces for more durability.
No other manufacturers that we know of take the time to vibratory finish the sprockets. Only Progear."
Basically if I was making a timing chain I would do it this way, hence why I use them.
Bret
Old Jul 19, 2007 | 09:29 PM
  #48
djk19's Avatar
bump ! to know as well. .. what part number for our lt1 cars minus the waterpump gear.??
Old Jul 19, 2007 | 09:44 PM
  #49
TravisA's Avatar
I'm going with the pg3145-1.
Old Jul 19, 2007 | 09:58 PM
  #50
djk19's Avatar
how much is it?
Old Jul 20, 2007 | 02:41 PM
  #51
bdc95ta's Avatar
Does it matter what series we get? 3000, 4000, TR? What's the best?
-b
Old Jul 20, 2007 | 04:18 PM
  #52
djk19's Avatar
Question
how much??
Old Jul 20, 2007 | 07:53 PM
  #53
MichiganSkip's Avatar
Originally Posted by djk19
how much??
you should contact the distributor in your area. the site has a locater to find one for your area.
Old Jul 20, 2007 | 07:58 PM
  #54
RedLT4Mike's Avatar
I'm running a ProGear timing set.
I was told by my local builder that it was
very good.
I'm also running an E-Water pump of course.
Old Jul 27, 2007 | 07:46 AM
  #55
Dave1980's Avatar
Originally Posted by TravProcharged94Z
So what part# do you usually use? PG4145, PG4145T, PG3145T or PG3145?
Thanks!
So what was the right 4000 set # for our app? (assuming youve got electric WP)
On a side note, I see they sell LT1/LT4 sets or did. I wonder how those looked, and price variance between the SB set.
Old Jul 27, 2007 | 09:14 AM
  #56
djk19's Avatar
their site is not easy to follow and they do a horrible job of organizing and explaining things. maybe if they are sogood at making timing sets they should hire somone to make them a new website and catalog...
Old Aug 18, 2007 | 01:50 AM
  #57
maro z28's Avatar
What part # for a 95 TA?
Old Aug 18, 2007 | 10:16 AM
  #58
Klaus's Avatar
Progear PG3-9100ST?
Does anyone know anything about the Progear PG3-9100ST? It is listed as their 3000 series setup for the LT-1, LT-4 1994 - 1997.
http://www.progearweb.com/chevrolet/chevrolet_3000.htm
Old Aug 18, 2007 | 12:05 PM
  #59
djk19's Avatar
you have to look for the reseller near you and call them. they should help more with applicatioin and pricing as the reseller can mark up or not. I had ordered a cloyes dual roller with multi keyways and it looks pretty nice. I am not going to worry about the single chain progear drive unless i'm putting down some serious power in a different then stock engine. I think they can be a little more pricey for the 3000
rideordie
Nov 5, 2019 04:52 PM
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
Feffman
Oct 9, 2015 05:42 AM
ddr698
Jan 9, 2015 10:05 AM
