What is the best LT1 Timing set for the money??
Old Jul 17, 2007 | 08:37 AM
  #31
MichiganSkip's Avatar
Originally Posted by SStrokerAce
Again the difference in ONE buildup and lots more than ONE. Yes I've had motors that have tried 3 sets till the Pro Gear worked perfectly, I've had the std cloyes set DEGREE IN PERFECTLY ONCE. I've had customers and builds in the shop where they are a problem to anyone with a degree wheel. I make sure that the cam is installed on the exact centerline that is should be. In fact having cams that come with readouts on how accurate they are ground and then having the timing chain throw it off is a pain in the ***. This even happened to Lloyd on his motor, the timing chain was off (it was a Cloyes) and the cam checked out fine. He put a Pro Gear on there and boom, it degreed in perfectly.
I don't know what your luck actually is, I still gotta think that ignorance is bliss for you. Some of us work in 1/2° and .0001" over multiple times and some of us work in close enough and it's good for me ONCE.
Bret
Who sells the ProGears?
Old Jul 17, 2007 | 08:52 AM
  #32
ZL1modified's Avatar
I'd rather be LUCKY than GOOD. Well I'm not lucky, just good. Good takes work too. Nobody thinks I'm the late JC either, just check the sig.
Originally Posted by SS RRR
The forefathers and ground breakers of modifying the small block Chevy who were able to make a successful living at it while writing "how to" books where their techinques are still followed to this day were good. Anyone else is just riding on the coat tails of poserdom. Thanks for trying though.
Are you two married? i always see you guys argueing here...
both of you sound like good engine builders so i think it would just come down to personal preference... i would buy the most expencive ones...
Old Jul 17, 2007 | 11:06 AM
  #33
djk19's Avatar
Question
wtf are ya'll talkin about!
Old Jul 17, 2007 | 04:12 PM
  #34
1racerdude's Avatar
Ya should have been there in the 265CID days and ya wouldn't have to do no coat tails.
Old Jul 17, 2007 | 04:58 PM
  #35
265CID? Man, you should change your screenname to "1oldfartdude"! I cut my teeth on the 265. I had a 55 Belair with glass nose and 4 speed. Ran the Gas class.
Old Jul 18, 2007 | 01:38 PM
  #36
1racerdude's Avatar
Most people I know at the track call me "old fart" I love it.
I had a '55 210 business coupe with a 300HP 327 crate engine. Had a '50 convertible too.
Old Jul 18, 2007 | 02:01 PM
  #37
1SlowFormula's Avatar
I was wondering the same thing, google doesn't seem to know either???
Old Jul 18, 2007 | 07:12 PM
  #38
djk19's Avatar
Wink
got my timing set today from summit. it is billet NOT cast. for sure. the chain looks pretty good. Nothing fancy. Double roller and it has the double roller sprockets. Should be plenty strong for anything I am doing for a good while. Definately a stock upgrade and it has the multiple key ways to set it and forget it
Old Jul 18, 2007 | 08:21 PM
  #39
SStrokerAce's Avatar
It's not that it's strong it's just try putting it in "straight up" with a accurately made cam and when it's +/- 5° off it's not close enough in my book.
Bret
Old Jul 18, 2007 | 08:32 PM
  #40
TravisA's Avatar
I'm assuming this is it?
http://www.progearweb.com/index.htm
Old Jul 18, 2007 | 10:31 PM
  #41
djk19's Avatar
sweet. there is a distributor right near me. well when I need somthing another time or if this one doesn't time in right then I know where I am going.
Old Jul 19, 2007 | 01:36 AM
  #42
Yep that's them... you need to make sure you get a TC for a 86+ SBC or they are gonna give you the wrong part.
Bret
Old Jul 19, 2007 | 01:44 AM
  #43
djk19's Avatar
do they have a picture of a true double roller setup?
Old Jul 19, 2007 | 01:45 AM
  #44
True double roller? Like two innterconnected chains? Uhhh no their chain is a ton stronger with a thick single roller
Old Jul 19, 2007 | 07:15 PM
  #45
TravisA's Avatar
Bret
So what part# do you usually use? PG4145, PG4145T, PG3145T or PG3145?
Thanks!
