What is the best LT1 Timing set for the money??
Old Jul 13, 2007 | 12:58 AM
djk19's Avatar
Smile What is the best LT1 Timing set for the money??
I can not for the life of me figure out what would be right for me. I can't afford the 500 dollar comp cams timing set but I am guessing I should get an adjustable set that is (what kind of roller) that is what I dont know. I can't waste money but I need the kind of set that can be swapped into an engine that has a forged rotating assembly being sprayed with 250 hp nitrous.
Old Jul 13, 2007 | 03:59 AM
SS RRR's Avatar
What year of car?
Old Jul 13, 2007 | 08:37 AM
djk19's Avatar
Red face
Look in sig. 95 Lt1. I want to do the timing set at the same time that I do the electric waterpump.
Old Jul 13, 2007 | 09:02 AM
Colin91Z's Avatar
If you're wanting an adjustable timing set, and you're using an EWP, then I would say go for the cloyes Hex-A-Just. Get the one that is listed for 87+ small block chevy w/oem roller cam.
I used one on my new engine, so I gotta warn you that you do have to modify a few things to make it work correctly...
First, the offset bushing thats used for adjustment is too long, it has to be ground down so that the opti will seat correctly on the dowel pin. This is also true about the allen head bolts that attach the cam sprocket to the cam, they need be trimmed too.
Finally, like any double roller you probably need to clearance the timing cover a little bit
Old Jul 13, 2007 | 09:33 AM
SevenStars's Avatar
Originally Posted by djk19
Look in sig.
Its not listed in your sig....
Old Jul 13, 2007 | 10:40 AM
djk19's Avatar
Lightbulb
Old Jul 13, 2007 | 01:38 PM
SS RRR's Avatar
I could've sworn when I posted that there was virtually no sig much less the year of car.
If you want durable chain and are doing an electric pump then do a double roller. The only thing you'll have to do is clearence the timing cover. There have been those who've used the LT4 H/D timing set w/ applications such as you want to do as well.
Old Jul 13, 2007 | 05:21 PM
djk19's Avatar
WEll I know about the lt4 set which costs $230.00 Cloys makes it and there is the same timing set for cheaper from cloyes. I wasn't sure if this was a good setup and what is SO superior with the comp cams setup??? Honestly?
Old Jul 13, 2007 | 06:30 PM
96capricemgr's Avatar
The stock timing set is plenty stout even with the load of the waterpump placed on it. Going to an electric WP will reduce load effectively making it even more reliable. Not adjustable but despite the rumors it is reliable and the price is reasonable.
Old Jul 13, 2007 | 06:59 PM
djk19's Avatar
I'm not concerned with any more "load" on the chain. I just want to make sure I have a nice set in there that I can swap to another engine later because I only do things once. I have to think ahead. What is the difference with the heavy duty set, and a comp cams set?
Old Jul 13, 2007 | 07:01 PM
SStrokerAce's Avatar
Are you running a electric water pump? I have found the Pro Gear Timing Chain for a 86+ SBC the best for the money by far.
Bret
Old Jul 13, 2007 | 07:54 PM
Bersaglieri's Avatar
I've had excellent luck with my Cloyes true double roller. It was only $80
-Dustin-
Old Jul 13, 2007 | 07:56 PM
mdacton's Avatar
-Dustin-
Same here....
and before I used that I just kept using stock style for years
Old Jul 13, 2007 | 11:55 PM
djk19's Avatar
Question
You can only use an lt1 specific 3 key setup right?? (is that the best)??? No one has backed up why a part is good more then "it works".... Whats the deal. Get scientific on me.
Old Jul 14, 2007 | 12:03 AM
To run a Cloyes double roller, you must have a 95+ Vented opti, E-WP, and clearance the 95+ timing cover to fit it. Sounds like alot of work, but not when you get a much better than stock, double roller setup. Stock is single and so is all the other LT1 specific timing sets. You just pay a bunch more for that lil waterpump gear and the extra teeth on the back of the cam sprocket. Thats about as scientific as I feel like getting a 1am before a 9 hour drive to Virginia and back.
-Dustin-
