what is the absolute easiest way to make 450rwhp w/o spraying?
Old Dec 12, 2003 | 12:57 AM
  #31
DrewHMS97SS's Avatar
i would just go stroker. you will not see a big enough gain with boost unless you go absolutly mad with it. For instance, an 8# boost on a strong 350 bottom end and a healty cam could push 5-550 HP at the flywheel. why not build a 383 and go high CR for 600-660 and spray?
Old Dec 12, 2003 | 01:01 AM
  #32
97WS6SCharged's Avatar
How strong of a bottom end are you talking about? For a low compression, forged bottom end, 8 PSI is almost nothing. You could easily turn the boost up to 14-15 PSI if everything is in good condition and see well over 550 hp. 600+ on a stroker will require N2O unless you get crazy with your compression and cam selection. Plus, you don't have to keep refilling bottles for a supercharger to work.
Old Dec 12, 2003 | 01:46 AM
  #33
ive seen quite a few 383's push 660+ off the bottle. ~12.5 CR will do it if you work it right. you dont need an insane cam, the heads are more important.
Old Dec 12, 2003 | 02:05 AM
  #34
eagleknight97's Avatar
All this talk of money and horsepower is making my head spin! But, in all seriousness, a good strong stroker built correctly should have no problem pushing 450rwhp. I would love to see one of those babies in my car, however, college and mods do not go hand in hand!
Old Dec 12, 2003 | 02:06 AM
  #35
DrewHMS97SS, I know I have heard that name before! Were you over on the SLP board? I was a long time reader, short time poster over there, but im sure i remember your name somewhere.
Old Dec 12, 2003 | 05:24 AM
  #36
rskrause's Avatar
Moderator
A 660+hp NA LT1? I'd be curious what the specs of that motor were.
Rich Krause
dluna333
15
Mar 13, 2015 12:30 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
CaRParts102
Dec 6, 2014 08:45 AM
