Using cc 943 spring on a XE230?
Old Dec 11, 2003 | 10:25 PM
BPS's Avatar
BPS
I'm getting advice from a shop that i can us the CC943 spring (spec's below) in combination with a R lifter on a comp cam xe230 grind
I believe that znines uses a 943 and type R combo as well.
Does anyone have any comments/suggestions/ warnings??
I would think that some of the dangers may be that I loose power turning this combo and will wear down the lobes faster.
thanks
cc 943 pacaloy valve springs ; com cams
1.550 in. O.D. outer, .812 in. I.D. inner, dual pacaloy valve springs
Clsd seat pressure 240 lbs
open seat pressure 598 lbs
coil bind is 1.150
spring rate 551 lbs/in
Old Dec 11, 2003 | 10:42 PM
rskrause's Avatar
Moderator
Re: Using cc 943 spring on a XE230?
thanks
coil bind is 1.150
What are the cam specs? If it's an HR cam, that's more spring than anyone uses and probably more than is needed.
Rich Krause
Old Dec 11, 2003 | 11:01 PM
BPS's Avatar
BPS
Sorry - yes it a HR cam
either
Comp Cams XE 230 / 236, .510 / .520 (1.5) 112 LSA,
or 224/230 duration @ .050", .536"/.544" lift
The issue is that the heads come with a basically new set of springs and retainers and I'm told I can use them rather then buy a new set -
So the question is - what's the downside.
Old Dec 12, 2003 | 05:48 AM
rskrause's Avatar
Moderator
either
Lots of wear/stress on the other valvetrain components. Rockers, lifters, pushrods, cam, valve seats, will all have decreased longevity with high pressures. Stiffer springs also produce more heat and generally will not last as long. Otherwise, everyone would be running the stiffest spring they could get. Those Pacalloy springs are expensive. Twice the price of a conventional spring. I bet you get sell them for at least the price of new set of more appropriate springs like the Comp #977 or #978.
This is an LT1 or least some small block Chevy, right? The #943 spring has a 1.555" OD, bigger than what is installed on most SBC heads. Are the valves really huge or something? Unless it's a big block with huge (heavy) valves, this is simply too much spring.
Rich Krause
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Catmaigne
Jul 14, 2015 05:17 PM
