what is a 377
Old Dec 19, 2009 | 02:18 AM
Brad.S Camaro's Avatar
what is a 377
I read an article (Cam-O-Rama) in popular Hot Rodding. They built a LT1 and said it was a 377 with a 5.850 inch rod and an Eagle cast crank. I was wondering if this is a standard 4.000 in bore with a stroker crank or what the heck is it? Sorry if this is in the wrong forum. I tried to find it in calculations but no luck.
Old Dec 19, 2009 | 05:33 AM
MikeGyver's Avatar
4.155" bore, 3.48" stroke
Gen1 motors used a bored over 400 block and a 350 crank.
Old Dec 19, 2009 | 06:31 AM
But you can't bore an LT1 to 4.155. You would have to sleeve it.
4.00 bore x 3.75" stroke = 376.99 CI
Old Dec 19, 2009 | 12:41 PM
lt1andy's Avatar
STD 350 bore (4.00) and 3.75 stroke
Old Dec 19, 2009 | 03:04 PM
JAKEJR's Avatar
One of the mags ran side by side tests between a 383 and a 377, built the same, other than the cubes/strokes. It's the old stroke Vs RPM debate rearing its ugly head once again.
The results were predictable, more torque (383) Vs slightly more high RPM HP (377).
I've forgotten what mag I saw it in, but I'm sure I have it around here somewhere.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Old Dec 19, 2009 | 03:07 PM
JAKEJR's Avatar
BTW, Bore x Bore x Stroke X .7854 x 8 will let you play with the CID of various combinaions, just in case you don't find a calculator online.
Jake
Old Dec 19, 2009 | 03:16 PM
n2ceptor's Avatar
Good site for calculating:
http://www.csgnetwork.com/automotiveconverters.html
Old Jan 16, 2010 | 03:31 PM
Thanks all. good info
Old Jan 16, 2010 | 08:10 PM
brucer's Avatar
they use a dart -little m block..
if i'm not mistaken i seen an article on a 454 smallblock they did a buildup on.
Old Jan 16, 2010 | 09:21 PM
Then its not an LT1, because no one makes an aftermarket LT1 block.
Old Jan 17, 2010 | 01:51 AM
brucer's Avatar
correct its gen1
Old Jan 17, 2010 | 04:13 PM
brucer's Avatar
the 377's ive seen use a smallblock 400 block, with a smallblock 350 crankshaft, they use bearing spacers on the main bearings
Old Jan 17, 2010 | 06:03 PM
The OP was asking about an LT1, not a Gen 1.
Slick_Sammy
Advanced Tech
Nov 28, 2006 11:55 PM
Slick_Sammy
Classic Engine Tech
Nov 22, 2006 01:46 PM
jkucz31
May 2, 2006 09:12 PM
IgorT.455/406
Classic Engine Tech
Jun 13, 2002 08:31 PM
