Welding stock rear end axles to pumpkin?
Old Dec 4, 2003 | 10:53 AM
  #16
BitCypher's Avatar
"If it ain't broke, don't fix it."
Some other unrelated part of the 10-bolt will break before the axle-tube-to-pumpkin connection becomes an issue. On another note, adding a TA girdle cover can help strengthen things a bit as well as help with lubrication dispersion/cooling.
Old Dec 4, 2003 | 11:07 AM
  #17
Robert95z's Avatar
I ordered the TA cover, im getting my gears installed december 15th and gonna have my installer put the cover in and set the studs for me
-Robert
Old Dec 4, 2003 | 11:13 AM
  #18
BitCypher's Avatar
-Robert
Sounds like a good plan!
Old Dec 4, 2003 | 02:42 PM
  #19
Grease's Avatar
Get a solid pinion spacer as well, they are only about 26$. The other weak part in our diffs are the posi units, if you can afford 300-450$. A cheap laternative would be an SLP take off unit for 100$.
Thats about the most you can do to the rear end. You could weld the axle tubes and get moser axles but it would be pointless so long as you have the stock sized gears.
Old Dec 4, 2003 | 06:26 PM
  #20
Robert95z's Avatar
Well I already have the "thick" gear to fit my 2 series carrier. What i thought was if you have the "thick" gears you cant use that spacer. But if u have a 2 series carrier and want to use a 3 series carrier ring and pinion then u would have to use the spacer?
Unless im totally wrong?
-Robert
Old Dec 5, 2003 | 11:23 AM
  #21
Grease's Avatar
Solid pinion spacers have nothing to do with gear thickness.
Old Dec 5, 2003 | 11:40 AM
  #22
-Robert
Ratech solid "spacer" replaces the pinion shaft "crush sleeve".
oldschool
Feb 9, 2016 09:21 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
