Welding stock rear end axles to pumpkin?
"If it ain't broke, don't fix it."
Some other unrelated part of the 10-bolt will break before the axle-tube-to-pumpkin connection becomes an issue. On another note, adding a TA girdle cover can help strengthen things a bit as well as help with lubrication dispersion/cooling.
-Robert
Originally posted by Nox1d3
I ordered the TA cover, im getting my gears installed december 15th and gonna have my installer put the cover in and set the studs for me
Thats about the most you can do to the rear end. You could weld the axle tubes and get moser axles but it would be pointless so long as you have the stock sized gears.
Originally posted by Grease
Get a solid pinion spacer as well, they are only about 26$. The other weak part in our diffs are the posi units, if you can afford 300-450$. A cheap laternative would be an SLP take off unit for 100$.
Unless im totally wrong?
-Robert
Well I already have the "thick" gear to fit my 2 series carrier. What i thought was if you have the "thick" gears you cant use that spacer. But if u have a 2 series carrier and want to use a 3 series carrier ring and pinion then u would have to use the spacer?
-Robert
-Robert
oldschool
Feb 9, 2016 09:21 PM
