Weird cruise control problem
Old Aug 4, 2003 | 11:15 PM
Joe Brodman's Avatar
GP Moderator
Exclamation Weird cruise control problem
The car has done this for a while, but has being consistant now.
The cruise control works, just not the way it should.
Normally, to set the cruise you simply have the switch to on (duh), the push the set/decelerate button on the side of the stalk. But that doesn't do anything when I do it.
If I hold over the resume/accelerate switch for about 2 seconds, THAT sets the cruise control. The button for decelerating works just fine, as done the acceleration button. Just oddly, the set button won't set the cruise.
Guess this really isn't a problem, since the cruise does work. Just kinda annoying. Any ideas?
Old Aug 5, 2003 | 08:43 AM
GP Moderator
I discovered on my drive to work this morning, you have to push the set button just once before holding down the resume button for the cruise to activate. Otherwise, holding down resume won't activate the cruise control. Weird.
Old Aug 5, 2003 | 02:50 PM
Mtrhds94Z's Avatar
Pretty sure my 94 is the same way.
I don't use it much,but I'll check that later to verify.
Old Aug 5, 2003 | 03:14 PM
GP Moderator
Mine used to not be that way, used to just set the cruise when you hit the set button. Damn odd problems.
edman
Mar 13, 2015 09:39 PM
dluna333
15
Mar 13, 2015 12:30 PM
97z28k&N
Jan 9, 2015 04:58 AM
jayblev95
Jan 6, 2015 11:52 AM
slothgrant
Aug 22, 2002 03:01 PM
