VRE 383 with LE3 Package Finally being Dynoed!!
Old Feb 1, 2006 | 11:57 AM
ChrisUlrich's Avatar
It's a 383 put together by Nick at Victory Racing Engines.
Lloyd Elliot Stage 3 Setup (Heads/Cam/Intake)
2.06/1.60 Valves.
Cam is 240/245 with a 59x/61x Lift on a 10x LSA.
Heads Flow Numers are here ( http://web.camaross.com/forums/showthread.php?t=418967 )
Fully Ported Intake by Lloyd
1.6rr
Chromoly Pushrods
Comp Lifters
BBK 58mm TB
Pacesetter LTs
Pacesetter Y
SLP Cat back (Loudmouth II Muffler)
Eagle Crank
Eagle Rods
SRP -5cc Dished Pistons
11.9:1 scr
8:1 dcr
Walbro 255lph Fuel Pump
37lbs Injectors
ATI Super Dampner
Mcleod Street Twin
10 Bolt
6 Speed (Stock Trans)
I'm at Sealevel by the way (Jersey) and not totally sure on how the weather is going to be.
Being dyno tuned on Friday... any guesses?
EDIT* www.angelfire.com/nj4/96blackws6/ VRE_383_LE3_Dyno.jpg
Old Feb 1, 2006 | 12:04 PM
TQdrivenws6's Avatar
Re: VRE 383 with LE3 Package Finally being Dynoed!!
I'll bite...433rwhp@6150rpm and 410rwtq@4600rpm with the 10 bolt/m6 dyno queen combo.
Old Feb 1, 2006 | 12:05 PM
T/A KID's Avatar
Man I have a feeling this thing is going to DYNO WELL. 6speed, 10 bolt, Nice heads and a badass cam on a 383 with a 11.9 compression.
HMMMM
Going to say if its on a DYNOJET, around 465RWHP and 435RWTQ.
BTW I like the 108 LSA get a CLIP of this thing.
Old Feb 1, 2006 | 12:10 PM
T/A KID's Avatar
I dunno maybe I am just Bias but I have a lot of faith in LE's heads as of Lately, on a 383 auto with a 3500 stall with a LE2 head and custom cam in a impala they just hit almost 440RWHP. It may be in the 440 range but It seems this guy has his ducks in a roll, A true duel system would yeild some gains I believe.
Old Feb 1, 2006 | 12:24 PM
Honda Hunter's Avatar
I'm not sure but I hope your numbers are high because my mods are almost the same. I made the same thread about my setup but didnt get much feedback. I cant wait to see your numbers. Did you work out all the bugs?
Old Feb 1, 2006 | 12:30 PM
LT4POWR's Avatar
HMMMM
I was thinking the same. Mostly gonna depend on the quality of the dyno tune. I'm still ready to see a 500rwhp hydraulic roller LTx stroker...I think we'll see a couple this year.
Old Feb 1, 2006 | 12:50 PM
I dont see even 450rwhp in that setup. The LT1 head doesn't have the capacity to feed a 383 to the revs necessary to achieve that kind of power. The LT1 intake, even ported, is a restriction unless you really do some serious work to it like Squinn's LTx.
The only way I could see 500rwhp out of an LT1 casting is a 355 with 12.5 compression peaking at or near 7000rpm with a solid roller and a super vic.
Old Feb 1, 2006 | 01:19 PM
Deenasty's Avatar
I am anxtious to see this combo. You are running slightly larger valves than me, but im running AFR's. You got slightly more compression, and a dyno queen 10 bolt, and no cats. My numbers are in the sig, with my ignition problem.. Then again mine is an LE2 combo..
Old Feb 1, 2006 | 01:39 PM
MEAN LT1's Avatar
450-460rw is my guess. Good luck.
Old Feb 1, 2006 | 01:48 PM
JustNO's Avatar
~450rwhp
You have said its your daily drive car. Is it really?
Old Feb 1, 2006 | 02:12 PM
LT4POWR's Avatar
Good point, I agree. I wasn't meaning an LT1 head casting...I was thinking more along the lines of LT4, AFR, and TFS casting. I do think it's possible (and will happen) w/ well built stroker, ported LT4 intake, hydraulic roller, stock pcm.
Old Feb 1, 2006 | 02:15 PM
SStrokerAce's Avatar
I'd have to agree Ty... one is sitting in the shop waiting.
Old Feb 1, 2006 | 03:49 PM
Leem927's Avatar
475hp
Old Feb 1, 2006 | 05:21 PM
T/A KID's Avatar
HotRodHawk on this forum made 505RWHP with LT1 heads (Right at 280 range), 12:5 compression, Single plain, with an auto and a BIG HR cam at around 7000 I believe. A well down LT1 head can do it, put it takes a nice size cam and A nice intake "cough" single plain to do it.
Last time I talked to him Denny Mcclain made 485RWHP with his 385 with LT4 intake and heads, with a HR in a 6-speed. I think I actually have the graph is someone wants to host it.
A few have hit that with heads that were not even worked over that well on Stock Bottom End N/a Cars.
Sar2k comes to mine in this application, 445RWHP with a stock LT1 shortblock, 248/254 HR cam right at .600 lift, ported LT1 heads and intake, by himself that peaked at 250CFM . Theres something going on there besides head flow you think, lol. made max power at 6600 RPM
As far as LT1 heads being able to support a 383, I think it all depends on the flow characteristics of the head, and along with many other attributes.
B/c there are some pretty strong Lt1 383's out there.
ChrisUlrich
What type of springs is in this setup, and retainers.
And you need to get a EWP, specially since this thing will spend to 6700-7000.
Comp is about to come out with a new Beehive spring that will handle a lot more lift than the .600 918 springs. Don't ask me how I know this, lol
Old Feb 1, 2006 | 05:25 PM
Zigroid's Avatar
Best of luck to you! Im gonna say 443rwhp and 417 rwtq.
Hopefully I'll be makin a thread like this in... lets see... a few years lol.
