VRE 383 with LE3 Package Finally being Dynoed!!
It's a 383 put together by Nick at Victory Racing Engines.
Lloyd Elliot Stage 3 Setup (Heads/Cam/Intake)
2.06/1.60 Valves.
Cam is 240/245 with a 59x/61x Lift on a 10x LSA.
Heads Flow Numers are here ( http://web.camaross.com/forums/showthread.php?t=418967 )
Fully Ported Intake by Lloyd
1.6rr
Chromoly Pushrods
Comp Lifters
BBK 58mm TB
Pacesetter LTs
Pacesetter Y
SLP Cat back (Loudmouth II Muffler)
Eagle Crank
Eagle Rods
SRP -5cc Dished Pistons
11.9:1 scr
8:1 dcr
Walbro 255lph Fuel Pump
37lbs Injectors
ATI Super Dampner
Mcleod Street Twin
10 Bolt
6 Speed (Stock Trans)
I'm at Sealevel by the way (Jersey) and not totally sure on how the weather is going to be.
Being dyno tuned on Friday... any guesses?
EDIT* www.angelfire.com/nj4/96blackws6/ VRE_383_LE3_Dyno.jpg
2.06/1.60 Valves.
1.6rr
Chromoly Pushrods
Comp Lifters
BBK 58mm TB
Pacesetter LTs
Pacesetter Y
Eagle Crank
Eagle Rods
11.9:1 scr
8:1 dcr
37lbs Injectors
ATI Super Dampner
Mcleod Street Twin
10 Bolt
Re: VRE 383 with LE3 Package Finally being Dynoed!!
Man I have a feeling this thing is going to DYNO WELL. 6speed, 10 bolt, Nice heads and a badass cam on a 383 with a 11.9 compression.
HMMMM
Going to say if its on a DYNOJET, around 465RWHP and 435RWTQ.
BTW I like the 108 LSA get a CLIP of this thing.
HMMMM
I dunno maybe I am just Bias but I have a lot of faith in LE's heads as of Lately, on a 383 auto with a 3500 stall with a LE2 head and custom cam in a impala they just hit almost 440RWHP. It may be in the 440 range but It seems this guy has his ducks in a roll, A true duel system would yeild some gains I believe.
I'm not sure but I hope your numbers are high because my mods are almost the same. I made the same thread about my setup but didnt get much feedback. I cant wait to see your numbers. Did you work out all the bugs?
HMMMM
HMMMM
I dont see even 450rwhp in that setup. The LT1 head doesn't have the capacity to feed a 383 to the revs necessary to achieve that kind of power. The LT1 intake, even ported, is a restriction unless you really do some serious work to it like Squinn's LTx.
The only way I could see 500rwhp out of an LT1 casting is a 355 with 12.5 compression peaking at or near 7000rpm with a solid roller and a super vic.
I am anxtious to see this combo. You are running slightly larger valves than me, but im running AFR's. You got slightly more compression, and a dyno queen 10 bolt, and no cats. My numbers are in the sig, with my ignition problem.. Then again mine is an LE2 combo..
Last time I talked to him Denny Mcclain made 485RWHP with his 385 with LT4 intake and heads, with a HR in a 6-speed. I think I actually have the graph is someone wants to host it.
Sar2k comes to mine in this application, 445RWHP with a stock LT1 shortblock, 248/254 HR cam right at .600 lift, ported LT1 heads and intake, by himself that peaked at 250CFM
. Theres something going on there besides head flow you think, lol. made max power at 6600 RPMAs far as LT1 heads being able to support a 383, I think it all depends on the flow characteristics of the head, and along with many other attributes.
B/c there are some pretty strong Lt1 383's out there.
ChrisUlrich
What type of springs is in this setup, and retainers.
And you need to get a EWP, specially since this thing will spend to 6700-7000.
Comp is about to come out with a new Beehive spring that will handle a lot more lift than the .600 918 springs. Don't ask me how I know this, lol
