Voltage problems
Old Mar 22, 2003 | 02:19 PM
Don't Look Back's Avatar
Voltage problems
Hey guys....I noticed when I am sitting at idle at a light, my volts go from about 13 to red lining at about 8. This is occuring with the radio, fan, lights, and fogs on, so I expect a little drop off in volts, but not this much. I have a brand new alternator, and my ignition switch is new, I can't think why this is happening. I brought it into my cousin's shop, and he hooked up at voltometer to the battery to make sure my gage was correct, which it was. He said his car does the same thing cause he has ubderdrive pulleys. The guy before me did some stuff to the car, but I'm not sure about the pulleys. Any ideas about this?
Old Mar 22, 2003 | 02:50 PM
If you have stock pulleys, your voltage should not go that low. Guess you need to see if you have any aftermarket pulleys.
Old Mar 22, 2003 | 02:54 PM
Alright, thanks, Shoebox. What is the best way to tell if I have aftermarket pulleys, I mean, what do I look for?
Old Mar 22, 2003 | 03:18 PM
DubbyZ28Camaro's Avatar
Look on the crank hub...if there are two pullies on the crank hub (probably a fancy pulley and the factory harmonic balancer) then you have the underdrive pulleys. If there is one, you do not have the underdrive pulleys.
Also, be aware that a lot of the alternators that are installed are rebuilt ones and sometimes do not function like a brand new ones. You might have just got a muffed up alternator.
Just my .02
Old Mar 22, 2003 | 04:28 PM
n2ceptor's Avatar
If its not the pulleys, how old is your battery...It could be a bad cell... Your reading should be close 14.2 volts with the engine running....
blac94Z
Mar 20, 2015 09:58 PM
Scottyboy
Feb 11, 2015 10:28 PM
pete53
Dec 9, 2014 07:31 AM
JSK333
Sep 9, 2002 10:33 PM
slothgrant
Aug 22, 2002 03:01 PM
