View my Datamaster file
I have had problems with my camaro and the fans only coming on with the a/c on and if the a/c is not on, they do not come on and the car will overheat if sitting still for a period time.
Reference thread:
https://www.camaroz28.com/forums/sho...ch+of+problems
Bought datamaster and ran it and finally got the file posted on my site...
Please view it and help me make some sense of things.
My Site
Reference thread:
My Site
Page Not Found
The page you tried to access does not exist on this server. This page may not exist due to the following reasons:
You are the owner of this web site and you have not uploaded (or incorrectly uploaded) your web site. For information on uploading your web site using FTP client software or web design software, click here for FTP Upload Information.
The URL that you have entered in your browser is incorrect. Please re-enter the URL and try again.
The Link that you clicked on incorrectly points to this page. Please contact the owner of this web site to inform them of this situation.
I already tried that. Gets me to your site. When I right click and "save as" it tells me Windows Exporer can not open the link. And as I said, its a .uni file and that limits the number of people who can look at it even if they can download it. Why not just do a .csv export from DataMaster and post it on a free FTP site? That's what everyone else does.
Alright check it out, I exported as a .csv file so it should just open up in excel or whatever. It is really long cause I tested for a while and revved it a couple of times. I didn't know which columns would be best to export so I just chose the ones that were on the main screen. Tell me if you need more or whatever. Thanks!
Log isnt long enough, according to the pcm the coolant never crossed over about 100f. Why did you terminate the log so quickly. Did your gauge already register that it was overheating when you shut it off?
Your pcm and your gauge get thier info from two seperate sending units. That would account for the difference in what the pcm is seeing vs the gauge. You could even try watching datamaster in the car vs the gauge in real time. Once you're sure they dont agree you're going to have to actually measure the coolant temp with something else to see which sensor is frigged up.
The actual datamaster file will show you when the fan relays are commanded on as well.
Alright I ran it for a long enough time for the gauge to register that I was overheating and I even drove it a little then when it got nearly in the orange on the gauge I turned the A/C on and watched the temperature drop back to normal.
betacortex.com
Click on Datamaster Log and it should work in most spreadsheet programs. Thanks!
betacortex.com
If I'm looking at it corrrectly(never saw one of these files before), it only gets to 108.5°C. Which is around 227°F. Not overheating, but still pretty hot.
Still doesn't help you with the fans not coming on, though.
