Vacuum Readings
Vacuum Readings
Anyone running a big cam, can you post your BAR & MAP readings or Vacuum readings at idle. I'm trying to chase down why my readings at idle are wierd and my service light comes on, but when I start drive the light goes off. Check DataMaster and it gives me 33,
Bar: 30.4
Map: 24.7
Cam Spec:
- Duration
242-I
252-E
- Lift
525-I
540-E
- Lobe Separation
112
Someone said I have a vacuum leak, but I've checked everything using both methods, propane & carb cleaner all around the intake and vacuum lines, but nothing.
Thanks,
Jody J.
Bar: 30.4
Map: 24.7
Cam Spec:
- Duration
242-I
252-E
- Lift
525-I
540-E
- Lobe Separation
112
Thanks,
Jody J.
Look at this:
http://members.aol.com/InjuneerZz/ScanMast.htm
It says in here that MAP readings for a radical cam should be about 18.
Re: Vacuum Readings
Originally posted by JodyJ
...... Check DataMaster and it gives me 33,
Bar: 30.4
Map: 24.7
Bar: 30.4
Map: 24.7
And, the link above is to my website, but the 18"Hg MAP is not a "one size fits all" number.
Stock cam in a 350 you would see about 10" MAP = ~35kPa.
My 230/242 114LSA in a 381ci engine MAP runs about 15.5"Hg. That's a pretty mild cam for a 381 and the 114LSA reduces the overlap, which is what kills vacuum.
The 245/252 112LSA is a BIG cam. What's it in? Didn't see a displacement anywhere. In a 350.... really big. I have no idea what the MAP should be, but 24.7 at idle sounds too high, and will definitely trigger the trouble code. There's a guy who posts on the Project TransAM BB LT1 Tech forum, TripnTaz... and he has a huge cam in a 383 and has had numbers similar to your if I recall.
Have you checked the valve adjustment?
Thanks for you replies guys.
Fred, sorry I didn't clarify properly. The 33 I mentioned is in regards to DTC33 (Low vacuum, High MAP)
BTW, this cam was spec. out/installed by my engine builder without talking with me. I knew I was changing the cam, but I didn't know it was that big of cam (long story).
This went in a 355ci with forged internals built for spray and a TH400 and P&P heads. Car drives great around town and and on the freeway and at WOT shifting at 7k RPM feels great :^)
Do you have a link to the Project TransAm BB?
I haven't readjusted the roller rockers since I got the car up and running two weeks ago, but I did adjust them to 1/2 pass zero lash before dropping the motor in.
Thanks again,
Jody J.
Thanks again,
Jody J.
z28projects4ever
9
Jul 16, 2002 07:48 PM
