vacuum canister
Old Mar 28, 2010 | 08:02 PM
chevyrules85's Avatar
vacuum canister
just wondering what the point of the stock one is? the line that runs down the passenger side with the group of wires there, seems like it runs into that long round cylinder mounted under the coolant bottle, as far as i can see, thats the only line that runs into that canister, just wondering what the point of that thing is? thanks guys
Old Mar 28, 2010 | 09:32 PM
The vacuum canister in the front fender is part of the HVAC vacuum control system. It stores vacuum, so there is a sufficient reserve during WOT operation, so that the HVAC duct flapper doors don't loose the vacuum the powers them, and move to their default positions. Shoebox has a diagram of the HVAC vacuum system. PArt #37 is the vacuum canister:
http://shbox.com/1/hvac_vacuum.jpg
Old Mar 29, 2010 | 04:39 AM
o see. so if i removed this, the doors would not function properly at WOT correct? so when just cruising, they would work ok? im just wondering becasue i broke that line at some point, and if they will only misfunction during WOT, ill just get rid of that whole line and canister, or is that a bad idea? thanks injuneer
Old Mar 29, 2010 | 05:17 AM
I don't know how the doors will work. I removed mine a long time ago, but the car never gets driven on the street, so I don't really care whether the doors work or not. The bigger your cam, the sooner you're going to run out of vacuum.
Old Mar 29, 2010 | 06:39 AM
The controls will work similar to what you are now experiencing. There will be no reserve vacuum during periods when engine vacuum is low (high engine load).
Old Mar 29, 2010 | 01:55 PM
hmmm i never thought about my cam..... :/ i just want my defrost to work in the colder mornings, i really dont care about much else,, id just like a little heat for the colder mornings here in pa... maybe ill take it out and see what it acts like, like i said, i broke the line and dont really feel like fixing it
anyways, could i run that vac line straight to the intake or do i still need that valve thats in there? i shouldnt need it right? thanks guys !
Old Mar 29, 2010 | 04:07 PM
What line did you break, and why can't you just replace it?
Old Mar 29, 2010 | 06:54 PM
Well it actually broke in two places. The three way valve thing where it comes off the manifold and down by the canister. I could fix it but I have biggger things on my mind ya know... If my defrost will work I think I might just leave it alone...
Old Mar 30, 2010 | 03:20 AM
ACE1252's Avatar
I can tell you this about when my vacuum check valve went bad.
I could go WOT with the system on the passenger vents and it would switch to the defrost vents. Then, when I got off WOT...it would come back to the passenger vents.
I could have the vents reversed, but it may not work at all without the canister. I have not tested the system without canister.
magman
Apr 15, 2016 03:08 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
