Vacume and AF guage...
Old Jul 13, 2004 | 10:56 PM
CoUnTryMuZiCZ28's Avatar
Where do you hook up an auto meter vacume guage to? What hose? Also where do you hook up and AF guage in our cars? PCM?
Old Jul 13, 2004 | 11:13 PM
Cmr0z28's Avatar
Hey Nick, I don't know about the vacuum gauge, but A/F gauges don't do crap. Just FYI.....all it is, is an annoying light show. They're not accurate at all.
Old Jul 14, 2004 | 06:35 AM
You can hook the vacuum gauge to any full vacuum port on the engine..... that would include the ports for the EGR vacuum, Opti vent, fuel prussure regulator vacuum or HVA/C system vacuum. Just put a "t" into the line as close to the port as you can get it.
The A/F ratio gauge needs to connect to the signal wire for either the left or right pre-cat O2 sensor. Those are pins C8 and C20 on the PCM, the wires are purple on one side and purple/white for the other. As noted above, you are not going to learn much from the A/F ratio gauge.
Check the wiring diagrams on Shoebox's Tech Pages for the wiring diagram for your 95, including PCM pinouts.
Amshnock
14
Jan 18, 2015 11:47 AM
bmillington
3rd Gen / L98 Engine Tech
10
Jan 4, 2004 11:38 AM
Blown350ZZ4
Dec 16, 2003 06:56 PM
Blown350ZZ4
Oct 19, 2003 09:49 AM
slayer6x6
Aug 12, 2003 05:02 PM
