Vaccum Question
Old Sep 20, 2004 | 12:23 PM
Deenasty's Avatar
Vaccum Question
Does anyone know how much vaccum you need in order for your brakes to work properly? I am running a 240/240 595/595 112 lsa, and after the car warms up, I checked the manifold vaccum with a guage and it is only making 9"!!! I dont have any vaccum leaks to my knowledge. My car idles at about 925-950 (M6). My IAC counts are at about 77..I called TPiS, being they are the cam designers, they said to close my throttle blades a bit, and readjust the TPS. But wouldnt this raise my IAC counts?
Old Sep 20, 2004 | 03:01 PM
Deenasty's Avatar
Re: Vaccum Question
anyone? Spinner? Mindgame? Injuneer? Shoebox?
Old Sep 20, 2004 | 03:04 PM
BlownF1's Avatar
Re: Vaccum Question
I've got a somewhat similar combo and I'm pulling between 12 and 14 with less than 100 miles on the motor...brakes work fine.
Old Sep 20, 2004 | 03:56 PM
Spinner's Avatar
Re: Vaccum Question
MY cam thats just a tad smaller then yours pulls just above 10" of vacuum. Brakes kinda suck dont they I know the feeling. Get a vacuum canister, it'll help a lot. They're pretty universal, and can be had for ~$50 from jegs or summit. Autozone might even carry them. If your still not satisfied, you can get a vacuum pump. Basically a little electric canister pump with a fitting. The brakes will run off of its vacuum, and not manifold vacuum. Most pumps can give ~20 lbs of vacuum, which is awesome, but some of them aren't cheap.
Blownf1: Your cam is a LOT smaller, and on a 114 lobe. Thats why you make vacuum.
Old Sep 20, 2004 | 04:21 PM
Deenasty's Avatar
Re: Vaccum Question
BlownF1, your cam is a lot smaller than mine, and its on a 114 like Spinner said, thats why you have vacuum.
Spinner, are you using a vacuum canister? I was looking at Jegs, and they have one for like 34.00. I was wondering if you think I can benefit from this? The cars brakes seem to work, but just not like they use to. I talked to a tech at TPiS, and he said that if I am facing a vacuum problem, either my brakes would work, or they wouldnt. Does that sound true? I thought the less vacuum, the less stoping power, but I guess he said its a work or no work thing..
Old Sep 20, 2004 | 05:11 PM
Spinner's Avatar
Re: Vaccum Question
I have the cheapy jegs canister on mine. Made a world of difference, though I'm considering putting a bigger one on it just because I can. The less vacuum, the less stopping power to a point. Basically thats because the master cylinder can only offer X psi of pressure per X vacuum. However, the amount isn't linear, its parabolic, and increases/decreases repidly at either end of the chart. Throw a canister on there, and see how you like it.
Old Sep 20, 2004 | 08:36 PM
Deenasty's Avatar
Re: Vaccum Question
Hey Spinner, I got home, adjusted my IAC counts, and readjusted the TPS, and installed a thicker line from my bellow (After the MAF) to the intake manifold to allow more air..I rechecked the vacuum, and now its making 11-12"!!! But im still going to get a canister
Old Sep 20, 2004 | 08:59 PM
RamAir95TA's Avatar
Re: Vaccum Question
I'm pulling 11.5" of vacuum with my cam, and it's just BARELY considered comfortable. I don't plan on picking up a canister simply because I'm comfortable with how the brakes feel.
Good luck with yours.
Old Sep 21, 2004 | 12:16 AM
BlownF1's Avatar
Re: Vaccum Question
I know they're different...you hadn't gotten any replies at that point and I was trying to give you a point of reference in that mine seems fine at 12-14". If you can get to that range, I think you'd be fine.
Old Sep 21, 2004 | 12:35 AM
Deenasty's Avatar
Re: Vaccum Question
thanks a lot, i will try to sweet talk her tonight, to see if she gives me more inches!!
Old Sep 21, 2004 | 06:53 AM
rskrause's Avatar
Moderator
Re: Vaccum Question
11-12" is the bare minimum for proper brake operation. A higher idle speed will help but a vacuum canister is often needed with that kind of vacuum and is a necessity if the vacuum is less.
Rich
Old Sep 22, 2004 | 06:38 AM
1982z28with18s's Avatar
Re: Vaccum Question
I pull 16" at idle in park, 13" in gear, and 8" with the a/c on(drops my idle to 650rpms, but I will soon be fixing that). Even with the a/c on the brakes still work, just not that great.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Hot Rod Hawk
Aug 15, 2002 10:47 PM
