Is this a vaccum hose feed?
Old May 22, 2011 | 10:32 PM
GMC5.3's Avatar
I broke one of these little hoses while taking off the intake manifold and was wondering what part number it may be or if i can just take it to autozone and they might know. The pic may be difficult to see being its off my cell phone, but its 1 of 2 little plastic hoses that comes out of the fuel pressure regulator i believe, Thanks
Old May 23, 2011 | 02:27 AM
gatorhead's Avatar
Re: Is this a vaccum hose feed?
Can't tell for sure from the picture, but you should be able to repair it with a small piece of hose
Old May 23, 2011 | 05:27 AM
LT1 engine connecti0ons vary by year. You have to add a "Signature" with basic info about your car - year, model, engine, trans and any major mods. Makes it very difficult to help you without that info.
Appears to be the radiator, but on a 4th Gen with an LT1 there is no vacuum piping, and no "pressure regulator" next to the radiator cap. And there is no EGR valve up against the radiator. Is the intake manifold off the engine, and sitting backwards on top of it?
Is this even in a 4th Gen F-Body?
Simple fix for vacuum lines - they have rolls of the plastic tubiong and displays of various fittings. You take the line you want to replace, and match the tubing diameter and the fitting shapes and sizes.
Old May 23, 2011 | 05:53 AM
Guest47904's Avatar
Guest
Is that supposed to be this?
I doubt it?
I'm confused. Didn't you just post yesterday that you had the heads off and was going to take them to a MS? https://www.camaroz28.com/forums/sho...d.php?t=813612
How did we get to this question so soon? Wouldn't this be evident when you reassemble it?
Old May 23, 2011 | 06:38 AM
Looks like you have some stuff disconnected and just laying about. The vacuum hoses look like what is in the lower center and right of this diagram:
http://shbox.com/1/air_pump_recall.jpg
Old May 23, 2011 | 11:59 AM
GMC5.3's Avatar
Sorry i should have stated that i layed the assembly over the radiator, i believe my sig should also be in place
I doubt it? It is apart of that i just didnt know if i could buy the tube itself
I did post yesterday that heads were off and taking them to a machine shop, during that process this happened, i didnt add to that thread due to all the questions i was already asking
So you can just purchase the tubing itself?
Old May 23, 2011 | 12:57 PM
Yes, you can purchase the rigid tubing at a parts store.
mmf_1013
Apr 11, 2015 11:03 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
number77
Classic Engine Tech
Aug 4, 2002 07:51 PM
