V6 to V8 Swap
Old Dec 18, 2003 | 01:04 AM
  #16
95patriotZ's Avatar
How new is the opti?
Old Dec 18, 2003 | 01:05 AM
  #17
95lt1&99ls1's Avatar
I knew you were going to say that.....
It is the second opti that i have put in the car. It was not a new one however it was out of a 95 car that had been wrecked. The problem is the same (old opti to new opti)
Old Dec 18, 2003 | 01:30 AM
  #18
any other ideas?
Old Dec 18, 2003 | 01:40 AM
  #19
RedPhenx's Avatar
have you checked the battery connections or the hot wire to the starter?
Old Dec 18, 2003 | 01:57 AM
  #20
yes...that is not the problem, the car cranks but will not fire
Old Dec 18, 2003 | 11:00 AM
  #21
any other ideas?
Old Dec 18, 2003 | 11:15 AM
  #22
turbo_Z's Avatar
sounds like possible opti problem to me. if you lose the low resolution pulse from the opti.. that will shut down the injectors and fuel pump. sometimes this happens just after start-up so the car dies after a sec or 2 and other times it happens right on start-up so the motor only cranks. maybe you have a bad connection to the opti??
Old Dec 18, 2003 | 02:35 PM
  #23
LWillmann's Avatar
Have you tried your cable in someone else's car to make sure that the cable is good?
If the wiring is run correctly for a 1995, and the cable is good, then I don't know what to tell you...
I do wish you the best of luck getting it going though.
Old Dec 18, 2003 | 02:37 PM
  #24
Thanks for the info I'll check that......
As for being wired correctly i believe it is....
Do you know if the BCM is the same for v6 and v8 cars?
Old Dec 20, 2003 | 11:22 PM
  #25
Thanks for everybody's help but....... It still doesn't work????????
Old Dec 20, 2003 | 11:38 PM
  #26
Mir Hussain's Avatar
Can you scan the car ?
Like view the sensors when its running (Like What AutoTap do to OBDII)
Is Airbags,ABS, and Cruise Control Module working ok ?
Old Dec 20, 2003 | 11:39 PM
  #27
no i can not scan the car at all......
GN tried also and they could not either...
Old Dec 21, 2003 | 12:08 AM
  #28
That mean you have hardware handshake with your PCM and Tech2.
That mean two things
1. Bad connector (Under the das)
2. Missing Wires!
Both are easy to confirm.
Old Dec 21, 2003 | 01:33 AM
  #29
I have already checked all of that....
Does anybody know if the bcm has anything to do with it?
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
