Two Problems
Old Jul 27, 2009 | 12:49 PM
joshmullins8's Avatar
Unhappy Two Problems
First one is I just had my engine rebuilt and when i went to fire it upo all it would do is click so I went over all the grounds and everything electrical but then my dad(Im only 17 so Im still learning so please help me) told me to unbolt the torqure converter from the flywheel and when I did that it fianlly started to crank over so Im guessing I now have a problem with my tranny? I was thinking that maybe I had the shifter cable in the wrong gear when I hooked it but I checked it and it seemed like it was in park maybe Im wrong. Any ideas what is wrong?
Second problem when I did get the engine to crank over it wasnt getting gas so Im guessing the furl pump is bad or the fuel injectors. Should I get a stronger fuel pump or biggier injectors , Im running the LT4 Hot Cam Kit and .030 Piston.
ANY HELP WOULD BE GREATLY APPRECIATED!!! Please help this is my first car and Ive put so much time and money into it and I just cant get it to start.
Old Jul 27, 2009 | 08:01 PM
You can't just keep starting threads about the same problems. This is the 3rd thread you've started in 3 days. On the preceding threads, several people responded, and in both of them, I asked questions that I thought might help solve the problem. You basically ignored those questions, and started yet another thread.
That's not the way to solve your problem(s).
https://www.camaroz28.com/forums/sho...d.php?t=701465
https://www.camaroz28.com/forums/sho...d.php?t=701113
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
