turning down the crankshaft
Old Jul 3, 2005 | 01:31 PM
hallbilly's Avatar
What is the most you can get the rod journals turned down on the crank?
Old Jul 3, 2005 | 05:00 PM
chuckd4more's Avatar
Re: turning down the crankshaft
Not sure but looking into rebuild kits, they come up to .030 under for rods, and .020 under for mains. I haven't seen any more than that. This is the only basis for this answer however.
Old Jul 4, 2005 | 03:50 PM
hallbilly's Avatar
hmm... i think the damage that is done to my crank is worse than that... http://photobucket.com/albums/a129/hallbilly/
there are a few pictures... guess i need to invest on some good measuring tools.
It looks unusable to me... but my eyes are not that calibrated!
Is a cast eagle crank a good replacement for ~420 rwhp and 6500 rpm?
Old Jul 4, 2005 | 03:58 PM
moparman's Avatar
Can't tell by the pics, but you should take it to a couple of machine shops and see what they say.
Old Jul 4, 2005 | 04:54 PM
WS6T3RROR's Avatar
i usually dont bother grinding cranks anymore. the scat and eagle stuff is just so cheap it comes out about the same cost of regrinding the old one. its also pretty much the same with rods. that and i'd rather run good rods and bolts and floating pins to save me the cost of having the pistons pressed on and off the rods and having them reworked.
Old Jul 4, 2005 | 06:19 PM
MachinistOne's Avatar
That crank is junk - easily seen in the pictures.
Old Jul 4, 2005 | 09:58 PM
hallbilly's Avatar
yea thats my second junk crank to come out of a camaro... now ive got to figure if i want to go eagle cast 200 bucks... or something else...
Old Jul 5, 2005 | 01:26 AM
You shouldnt be junking them like that....what is the problem with the oil system and clearances?
Old Jul 5, 2005 | 01:51 AM
Blownbird355's Avatar
Should be able to find a GM forged truck crank for a decent price. One piece rear of course.
Old Jul 5, 2005 | 07:22 AM
hallbilly's Avatar
well the first one was on my 91 rs... that was my mistake, overheated the oil and did not know much about anything when i was that young. this time I do not know why i had oil problems but when i put it back together i want that thing to be able to handle some pretty decent rpms for a long period of time.
HectorM52
Jul 30, 2017 11:46 AM
TitoPR221
May 26, 2015 12:20 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
formula79
26
Aug 5, 2002 12:21 PM
