trying to run without MAF??
Old Aug 20, 2012 | 02:36 PM
77amc's Avatar
I've been contemplating a 'different' design of an LT1 intake, but the way it would be situated, it would be near impossible to run a MAF. Kinda like a ITB setup.
Why? Because I don't like the sharp 90deg angle at the throttle body. And I could most likely get more flow..
SO, can someone give a 'quick' comparative between MAF and Speed density fuel injection.
I bought the book some time ago on GM fuel injection, but changed my mind a couple of times, so it didn't get read that much. And what I did read has been forgotten.
Thanks E
Old Aug 20, 2012 | 05:12 PM
96capricemgr's Avatar
Re: trying to run without MAF??
The 94+ LT1 pcm can handle speed density mode just fine. The tuner I have been using the last few years prefers speed density so for me the MAF is just basically a coupler.
I began running the y-pipe setup because there was only room for a very short filter inline and the inverted cone in the end of that filter made for screwy MAF readings back when I was using the MAF. Airflow needs to be even and smooth when it crosses the MAF or it can be erratic.
Old Aug 20, 2012 | 07:30 PM
77amc's Avatar
PM'd ya..
E
Old Aug 20, 2012 | 08:34 PM
77amc's Avatar
So give me a quick over view of what yer talking about..?
You know, for reference of course.
E
Old Aug 22, 2012 | 08:40 PM
77amc's Avatar
Hey, you wouldnt' mind giving me your tuners info would ya?
The guy that I was going to use doesn't like Speed density..
Errol
Old Aug 23, 2012 | 06:53 AM
pcmperformance.com
Was there something else about my setup you were wondering about?
Old Aug 23, 2012 | 12:55 PM
Nothing wrong with running speed-density, with a very good tune. The VE tables are critical.
http://www.injuneer.com/images/photo.../DCP03746a.jpg
Old Aug 23, 2012 | 03:53 PM
77amc's Avatar
VE= Volumetric efficiency right?
E
Old Aug 23, 2012 | 05:02 PM
Correct.
DirtyDaveW
Dec 1, 2016 05:37 PM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
RedLineRev
Jan 23, 2003 03:51 PM
