trying to run without MAF??
I've been contemplating a 'different' design of an LT1 intake, but the way it would be situated, it would be near impossible to run a MAF. Kinda like a ITB setup.
Why? Because I don't like the sharp 90deg angle at the throttle body. And I could most likely get more flow..
SO, can someone give a 'quick' comparative between MAF and Speed density fuel injection.
I bought the book some time ago on GM fuel injection, but changed my mind a couple of times, so it didn't get read that much. And what I did read has been forgotten.
Thanks E
Thanks E
Re: trying to run without MAF??
The 94+ LT1 pcm can handle speed density mode just fine. The tuner I have been using the last few years prefers speed density so for me the MAF is just basically a coupler.
I began running the y-pipe setup because there was only room for a very short filter inline and the inverted cone in the end of that filter made for screwy MAF readings back when I was using the MAF. Airflow needs to be even and smooth when it crosses the MAF or it can be erratic.
Nothing wrong with running speed-density, with a very good tune. The VE tables are critical.
http://www.injuneer.com/images/photo.../DCP03746a.jpg
formula218
Dec 2, 2014 04:27 PM
