Tried to bleed air out of the cooling system; no air or coolant in hoses..help?
Old Aug 3, 2005 | 08:01 PM
Black1995Z's Avatar
Arrow Tried to bleed air out of the cooling system; no air or coolant in hoses..help?
just finished rebuild and now my car its overheating, not even the fans are coming on. So I tried to bleed the system for air and nothing came out. Absolutely nothing, I tried both valves.
Old Aug 3, 2005 | 09:22 PM
Re: Tried to bleed air out of the cooling system; no air or coolant in hoses..help?
If coolant did not come out, then there is air in it (assuming there was some pressure). Did you properly fill the system and have the bleed valves open as you filled it?
Old Aug 3, 2005 | 09:44 PM
Black1995Z's Avatar
Unhappy Re: Tried to bleed air out of the cooling system; no air or coolant in hoses..help?
Well, I just filled her up with coolant and ran it idle ... I did not have the bleed valves open as I filled it. Suggestions??
Whats the proper way?
Old Aug 3, 2005 | 09:46 PM
Canuck wita WS6's Avatar
http://shbox.com/1/4th_gen_tech2.html#radflush
Old Aug 3, 2005 | 09:47 PM
The second part of this procedure describes filling it up.
Old Aug 3, 2005 | 09:50 PM
Black1995Z's Avatar
I pulled the big hose off of the waterpump on the passenger side.. the thermostat housing one and it was dry
DirtyDaveW
Dec 1, 2016 05:37 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
kksi
Feb 17, 2015 10:41 PM
squarehead
Jan 15, 2015 07:02 PM
