Tried to bleed air out of the cooling system; no air or coolant in hoses..help?
just finished rebuild and now my car its overheating, not even the fans are coming on. So I tried to bleed the system for air and nothing came out. Absolutely nothing, I tried both valves.
Re: Tried to bleed air out of the cooling system; no air or coolant in hoses..help?
If coolant did not come out, then there is air in it (assuming there was some pressure). Did you properly fill the system and have the bleed valves open as you filled it?
Whats the proper way?
Originally Posted by Black1995Z
Well, I just filled her up with coolant and ran it idle ... I did not have the bleed valves open as I filled it. Suggestions??
http://shbox.com/1/4th_gen_tech2.html#radflush
I pulled the big hose off of the waterpump on the passenger side.. the thermostat housing one and it was dry
Magenta_Hearts
Mar 25, 2015 10:24 AM
squarehead
Jan 15, 2015 07:02 PM
