tranny cooler question
Old Oct 22, 2003 | 12:35 AM
hey01's Avatar
Question tranny cooler question
i have read all the online installs of the tranny coolers. but it seems you are just disconnecting the stock cooler and replacing it, does the stock cooler suck that bad?? is there anyway to hook it up inline with the stock cooler? if so does anyone have a write up on it?
Old Oct 22, 2003 | 01:27 AM
Jay-Roll's Avatar
There is no real stock cooler. The lines just go into the radiator. It sucks really really bad at cooling the tranny fluid, it's actually almost useless. A 28,000 GVW B&M tranny cooler is like $60-70 bucks. All it does is unhook the lines from the radiator and run them through the aftermarket tranny cooler instead. Since the cooler is dedicated only for the transmission it's much much more efficient. BTW total install time for an amateur is probably less than an hour. Well worth the cost, IMO it's well worth any cost. Just about the best preventative measure you can take.
Old Oct 22, 2003 | 01:29 AM
hey01's Avatar
ohhhhhhhhhh ok i get it i though there was an actual cooler in the radiator like the stock oil coolers.
what do you think about mounting it in the passenger fender wheel well with vents cut into the fender well for it?
Old Oct 22, 2003 | 01:30 AM
S.J.S.'s Avatar
Even though its not technically a trans cooler, it does help a lot in cooling the fluid. As for the aftermarket one.....it runs inline with the stock cooling system. You're adding it on not bypassing the old one.
Old Oct 22, 2003 | 01:32 AM
hey01's Avatar
the 2 off brents site they are just un hooking the lines out of the tranny and running them into a new cooler.
Old Oct 22, 2003 | 01:47 AM
S.J.S.'s Avatar
What I did is run my line from the tranny into the aftermarket cooler than through the original inlet to the radiator. The exit stays the same. The stock system is technically a trans cooler my man. The after market one is just an auxilary cooler. It would be a bigger PITA to plug the old one.
Old Oct 22, 2003 | 01:51 AM
NewbieWar's Avatar
will the engine run cooler if u get a tranny cooler?
Old Oct 22, 2003 | 02:05 AM
Jay-Roll's Avatar
I doubt the engine will run any cooler but your tranny sure as heck will. I think almost everyone mounts theirs in front of the current radiator. Some say this inhibits air getting into the radiator and not allowing it to cool the engine temp down any but I haven't had any problems.
Also check out this site for a complete install with pictures.
Project Trans Am
Old Oct 22, 2003 | 06:27 AM
S.J.S.'s Avatar
Did you say that with a straight face????
Old Oct 22, 2003 | 09:03 AM
TedH's Avatar
Mine is mounted flat underneath. Works great.
Old Oct 22, 2003 | 09:06 AM
NewbieWar's Avatar
well i mean if the stock radiator is trying to cool down the tranny, then thats adding extra heat to the water, therefore if the cooling system only has to worry about the engine, it would take longer to heat and it would allow the water to cool a little more before its dumped back into the engine, but i donno thats just what i thought, maybe there is no difference
hey01's Avatar
chain it in before or after it goes thru the stocker.
and what do you guys think about the wheel well idea?
Old Oct 22, 2003 | 09:57 AM
When I converted to the TH400, from a T56, I had no tranny cooler in the radiator. I added a Perma-Cool fan assisted cooler, in the front of the drivers side fender. Handles an 800HP nitrous motor, 5K flash, non-locking convertor.
Trans cooler
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
RedLineRev
Jan 23, 2003 03:51 PM
Javier97Z28
Sep 8, 2002 07:23 AM
chesee48
Aug 22, 2002 08:28 AM
96z
Aug 2, 2002 09:00 PM
