Launching on my new 2800 Converter.. few ??'s...
Old Sep 6, 2002 | 12:56 AM
Javier97Z28's Avatar
Moderator
Post Launching on my new 2800 Converter.. few ??'s...
Hey guys.. I should be hitting the track either tomorrow or Saturday. This will be my first time running on my new Vigi 2800, Shift Kit, and on a set of borrowed skinnies as opposed to my ZR1's up front. I'll have bald center'd nitto's on the back on 16" firebird rims.
Any suggestions on the launch? What should I stall the car at? Nitto's around 19 psi?
I REALLY want to try to hit the 12's.. I know I shouldn't, but I've been getting my hopes up... do you think the car might have it in her now?
Javier
'97 Bright Green Metallic Z28
13.514 @ 101.86 (trapped 102 mph before as well, times before stall converter)
A4, 3.23, Hooker Catback, Hooker Longtubes, SLP Cold Air, Vigilante 2800 TC, Transgo SK, B&M Tranny Cooler, Hypertech 160* thermo, !TB Bypass, Hotchkis Panhard Rod, BMR Trailing Arms, Chrome 17x9 GM ZR1 Wheels, "Z28" Silver Reflective Concept Badges...
South Florida F-Body Association http://www.sffba.com
Old Sep 6, 2002 | 07:57 AM
T/A lt1's Avatar
Post
First try leaving at idle and flashing the converter and If you are hooking up hard you can brakestall it as high as it will go and mash it when the lights come down. That is what my car does it's best 60' with. It will depend on what you run in the 1/8th to wether or not you will run 12's. I think you will have a better shot with some 3.73's and better tires. Just my .02.
1995 T/A RamAir,17x9 WS6 polished rims,A4 Transgo 3:42's,LT4 Hotcam kit, mildly ported heads and intake, built 355 with forged pistons, LT4KM,NX N20 kit 125-175hp, Custom programming, AS&M headers, Vigilante 2800,
flowmaster catback, Fernco intake bellow,CSI w/p,MSD 6al, cutout. Everyday driver. New Et 12.50@107 N/A
11.61@117mph on N20. 1st decent N20 pass more to come!
Old Sep 6, 2002 | 09:26 AM
Moderator
Post
Your .02 is welcome As it stands it doesn't look like I have the MPH to do it.. I'm not sure how much I'll gain w/ the skinnies over the ZR1's up front. It might be enough.. but maybe not :/...
I'm not sure why my MPH isn't a bit higher tho :/
Javier
Old Sep 6, 2002 | 12:53 PM
kcsoz20's Avatar
Exclamation
I run my skinny's at 40 PSI for a better roll out. I run my Hoosier QtP's at 12 PSI hot.
I stall mine up to 1800 rpm. Last yellow lights, mash on the throttle, slammed back in the seat, hang on for a 1.69 60'.
If you are redlighting lower the pressure in your skinnies for a slower rollout.
Good luck,
Ken
95 Z28, BBK 52 mm throttle body, ported MAF ends, K&N CAI, ASP Pulleys, 160 thermostat, PCM by WWW.PCMFORLESS, LT4 KM, Heads by WWW.flow-technics.com, 2.055 int/1.57 exh. valves, 1.6 RR's, CC XE 230/236 544/556 112 LSA, Comp "R" lifters, Comp Magnum pushrods, FMS 24# SVO injectors, Meziere WP, Jet Hot coated Hooker LT's, Flowmaster cat back exh., PI Vig 2800-3000 TC, Strange 3.73 gears. Dyno numbers to come soon.
60' 1.690
1/8 7.674
MPH trap broke
1/4 12.059
MPH 113.00
My car www.teamnwfbody.org/members/mcdonald.htm
VID: CCXE230/236 thru Hooker LT's
Old Sep 7, 2002 | 12:22 PM
94_Z28_ragtop's Avatar
Arrow
Nitto's usually like a little more air pressure. I'd say start out with them at 22 psi hot. Do a good smokey burnout. Once you stage, brake torque it up to about 1500 rpm to preload the drivetrain and launch at that rpm. Basically, the converter will flash stall the rest of the way which will usually give you the best 60 ft if you don't spin. I've been able to get low 1.8 60 ft times on BFG drag radials with that method. I usually cut mid 1.7 60 fts on slicks. Those times are with a bad posi (one wheel wonder ). My Auburn Pro series diff gets installed this Tuesday.
-Scott
2002 Camaro Z28 M6 - Cutout, !Cats, Holley filter, SLP lid, ported MAF ends, FTRA. No weight reduction!
With mods: 12.824 @ 111.67 w/ 2.068 60 ft on Eagle GS-C's
Bone stock (@1300 miles): 13.467 @ 105.37 w/ 2.149 60 ft
94 Z28 Convertible A4 - Stock TB, intake, heads & short block! No weight reduction! Stock suspension (except LCA's)!
Best 1/4: 12.911 @ 104.49 w/ 1.81 60'
1990 Plymouth Laser RS Turbo - FWD, M5, ported head, 2.5" turbo back w/cat, K&N in modded intake can, Nitto DR's.
13.752 @ 101.51 w/ 2.227 60' @ 17 psi
[This message has been edited by 94_Z28_ragtop (edited September 07, 2002).]
Old Sep 8, 2002 | 07:23 AM
GJE94Z28's Avatar
Wink
You need to reall get the Nitto's hot. I flash the stall, seems to geet me the best 60 foot. I believe you have 12's in your set-up. Your at sea level, that helps. You just need to wait for some good cool weather, low humidity. It may be a while for that to happen, pretty toasty this time of year in Florida!! Good luck.
94 A4 Black 3.42 gears
160 stat
CSI elec. water pump
LT1 edit
Hot cam
K&N CAI
March crank pully
K&N air foil
MAS port/polished
LT4KM
Edelbrock headers 1 5/8.
Crane Gold 1.6RR
Stock Coil
MSD 6A
Vigilante 2800
Transgo shift kit
Best 60ft: 1.76
1/8 ET: 8.15 @ 85.07
1/4 ET: 12.80@105.88MPH
IndyZman
Oct 22, 2015 02:17 PM
Daluchman1974
Sep 11, 2015 06:12 AM
willie-d-nice
Feb 13, 2015 06:40 AM
mark0006
Dec 25, 2014 09:50 PM
96z
Aug 2, 2002 09:00 PM
